Results of MK3 high quality belts upgrade
Flaviu
(@flaviu)
Today I updated my MK3 with R3 parts and since I had to take it apart I also upgraded my belts to better ones from e3d https://e3d-online.com/gt2-belt-upgrade .
I hoped that I could improve ringing but sadly it didn’t help much.
I managed to get about the same belt tension status after the update as I had before (x:280; y:290) so I could compare the quality of the parts.
(Upper parts are old ones, below parts are with new belts, PLA, 2 perimeter shells, speed outline shell 40mm/s, speed inline shell 80mm/s)
I don’t understand what is causing ringing especially since the parts are only 30 mm high.
Veröffentlicht : 25/08/2018 6:52 pm
Nikolai
(@nikolai)
Re: Results of MK3 high quality belts upgrade
https://www.simplify3d.com/support/print-quality-troubleshooting/#vibrations-and-ringing
Just lower your printing speeds and compare the results.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Veröffentlicht : 27/08/2018 7:50 pm
