Replacing the PEI Sheet on a defective Smooth Plate from Prusa
I saw the video on removing the PEI sheet in order to replace it, ain't nobody got time for that.
HOWEVER, I had one of the defective sheets that Prusa shipped with some MK3S machines (which they replaced of their own accord) and I noticed that the PEI was starting to look loose.
So I picked at the corner and the PEI peeled right off! No freezing, no solvents, no scraping. It just peeled right off of both sides clean as a whistle.
This makes replacing the PEI a lot more attractive. Just thought some of you might like to know. Maybe the new PEI won't stick either. Not sure about that.
Also, what will happen if I try to print directly on the spring steel? Might be worth a try.
Posted : 04/02/2023 8:37 pm
