QuickChange mod for i3 MK3/S/+ printhead?
Page 3 / 5
towlerg
(@towlerg)
RE: QuickChange mod for i3 MK3/S/+ printhead?
@dimprov
Apologies, I misread, at $150 it sounds interesting.
Posted : 21/12/2020 12:09 am
Michal
(@michal-3)
Pitstop + Molex Micro-Fit 3.0
head
mounted
Posted : 28/12/2020 4:21 am
dimprov
(@dimprov)
How long does it take to disengage it from the extruder?
Thinking about it now, I don't foresee much need to swap out the extruder anyway, as xChange would require you to do.  It's generally the hotend that needs changing, not the extruder or the rest of it, like fans, pinda's, etc.
This post was modified 5 years ago 2 times by dimprov
Posted : 29/12/2020 5:37 am
Michal
(@michal-3)
Hardware-wise? Few seconds, I guess. After opening Pitstop: the only thing left is to disconnect molex connector.
It might require to readjust z offset.
Posted : 29/12/2020 8:39 am
dimprov
(@dimprov)
Here's yet another approach that allows changing out the hotend in seconds:
It was pointed out in the comments that the wired connections could also be made through the magnets, thereby speeding up the process even further.
Posted : 11/01/2021 6:46 am
@dimprov
I would stick with Pitstop.  It is already designed for the Prusa.
Posted : 11/01/2021 3:51 pm
dimprov
(@dimprov)
A new product offering to consider: Wam Bam Mutant
Posted : 13/01/2021 11:23 pm
@dimprov
Interesting.  I am not sure what to think about the terminals.  I am concerned they might vibrate loose.  I have that experience on rockets.
Posted : 14/01/2021 10:46 am
dimprov
(@dimprov)
Posted by: @cwbullet
@dimprov
Maybe red Lock-Tite?
If I had my druthers I'd rather use the system used by automatic toolchangers, because then you're already setup for that, whenever that happens.  However, that's for the future, and this is for the here and now.  By the time the future happens things will probably have changed anyway.
Posted : 14/01/2021 8:23 pm
Bill Marcy
(@bill-marcy)
@cwbullet
The Mutant is a great tool platform, I have been using it for a week now and it is "Slap yourself in the forehead" easy to use.  Now I have three hotends that can be swapped into place in about 5 seconds.  Makes working on that part of the printer almost a joy.
If you can imagine that.
Posted : 14/01/2021 8:41 pm
dimprov
(@dimprov)
I think the mutant is the best so far.  It's general purpose, and it looks easy enough that just about anyone can do it.  It doesn't require a linear rail like the xchange, and you can buy/print it today.  And apparently it already has momentum with the HeroMe, so you're not left holding a bag and wondering, "Uh, now what?"
This post was modified 5 years ago by dimprov
Posted : 14/01/2021 8:43 pm
Bill Marcy
(@bill-marcy)
@dimprov
Talk to Peter at Wham-Bam, he is a great guy and he will get you setup in no time.
My product engineer just printed out a dremel holder plate for the Mutant, and he is now trying to have it automagically drill out a simple PCB.
Posted : 14/01/2021 8:46 pm
dimprov
(@dimprov)
Posted by: @bill-marcy
@cwbullet
Thanks for your timely post!  That clinches it.  I'm gonna get me one.
Posted : 14/01/2021 8:51 pm
dimprov
(@dimprov)
@dimprov
I have doubts about getting a 3D printer to act like a CNC, but going the other way might work just fine:  put a mutant on my CNC and then I can quickly put a printhead on it and get it to print.... uh, after adding a heatbed I guess.  🙂
Posted : 14/01/2021 9:21 pm
dimprov
(@dimprov)
If you ask me, the bed level sensor (whether it be a Prusa Inductive sensor or a BL touch or whatever) should itself be removeable from the Mutant, because it's only needed at the very beginning for the bed leveling.  Otherwise, at least in my experience so far, leaving it on means it will eventually get snagged on something and it will either get destroyed or it will ruin the print that's in progress, possibly by creating a level shift.  If it were removeable, then it would be out of harms way and could also be shared among the printheads, rather than requiring each printhead to have its own bed level sensor.  That would be ideal.  I suppose a compromise would be to simply have some sort of cover that snaps over it to protect it after the initial bed leveling is finished.
Posted : 14/01/2021 11:03 pm
dimprov
(@dimprov)
Aha!  I think I have the answer: dedicate one "mobile mutant" plate to just the bed level sensor.  After the bed leveling is completed, remove it and then install the printhead.  Voila.
Posted : 14/01/2021 11:10 pm
Bill Marcy
(@bill-marcy)
@dimprov
That would work.  How about acustom G-code that causes an arm to spring up carrying the bed level sensor up with it?  It is reset at the beginning of the gcode through slicer commands?   Should be a two wire hookup, gotta figure out the actuator and how light you can make it.
Posted : 14/01/2021 11:23 pm
@dimprov
I am not so sure.  Removing it might require resetting live Z on the next print.
Posted : 15/01/2021 12:39 am
dimprov
(@dimprov)
@dimprov
If the height could somehow be made highly repeatable when it's lowered, I suppose that could work.  It's that requirement though that might make doing it that way a bit of a challenge.
I've seen some BLTouch "protectors" on thingiverse.  Basically they build a shell around the BLTouch and its little plastic probe so they don't get destroyed.  I suppose that might be sufficient, because the print is probably (?) ruined anyway if stuff is crashing into it.
I haven't yet seen anything for the Pinda, but maybe that's because it's less delicate.  Currently my Prusa I3 MK3 is offline because the pinda snagged something.  Rather than breaking the Pinda, though, it snapped the pinda support, leaving the Pinda to flap in the breeze and snag even more things.  I'll have to replace the printed part before I can use it again.    This doesn't happen often, but it also isn't the first time either, and I'm already tired of it and would like to prevent any future recurrences of it.
Well, maybe I'm asking for too much.  Pinda's are cheap.  Maybe just put one on every mobile mutant and simply drop in another printhead  whenever something breaks.
Posted : 15/01/2021 8:04 am
dimprov
(@dimprov)
I ordered the Mutant.  I had thought WAM BAM was based in Florida, but it seems they ship from China, so even with DHL it will probably take at least a couple of weeks to get it.
Posted : 15/01/2021 12:37 pm
Page 3 / 5
