Prusa Mk3 Front Z-axis frame brace/stiffener/reinforcement with M8 threaded rods
Solid feet and a paving stone helped reduce noise/vibration on my Mk3 improving both print quality and print speed capability. But there is still vibration at the top of the main frame. My Mk2s printers have triangulated Z-braces based around M8 rods which helped reduce vibration:
https://www.thingiverse.com/thing:1656945
My plan is to replicate this stiffening scheme for the Mk3. My recipe for each side of the printer, but primarily the control-board side which flexes more than the PSU side is below.
Prusa Mk3 Z-axis frame brace/stiffener/reinforcement BOM (per side):
Benefits of this approach:
Drawbacks of this approach:
Related projects:
Re: Prusa Mk3 Front Z-axis frame brace/stiffener/reinforcement with M8 threaded rods
I'd be interested in having reverse Z-braces, behind the Z-axis tower.
I looked at this, but in my estimation it would increase the footprint of the printer even more than front braces since the angle of the main rod would have to open up about 75-100mm beyond the rear of the printer to ensure proper clearances. This would involve an extra 3030 extrusion joint increasing part count and make enclosure fitment even more problematic.
Still, I prefer all bracing to be on the rear for aesthetics and easier accessibility of the print bed, so I may design for that too.
See jitx's Z-brace with fewer parts and a more elegant design here:
I abandoned the aforementioned approach and instead am using a modified einsy box with built-in stiffener and printed T-nuts. The left side of the chassis is just as stiff as the right-side now. Perfect. Have no idea if it improved print quality, but should help the chassis stay aligned during maintenance at least. I see no need to add rods to triangulate/truss the top gantry any more.
Re-use all your einsy box components and just print this:
https://www.thingiverse.com/thing:3476970
Or re-print all einsy components to have the hinge on the other side:
https://www.thingiverse.com/thing:3424832
