Power supply quick disconnect for Lack Enclosure? Has anyone done this
[Résolu] Power supply quick disconnect for Lack Enclosure? Has anyone done this
Page 1 / 3
MikiCab
(@mikicab)
Has anyone put quick disconnect on the power supply for the under the Lack Table modification.  I take have had to take the printer out several times for repair and having to remove the cables each time is a pain.  Anyone have a solution?
Thanks
Best Answer by cwbullet:
I have with XT60 connectors.
Publié : 06/10/2019 12:17 am
Membre
RE: Power supply quick disconnect for Lack Enclosure? Has anyone done this
Publié : 06/10/2019 12:29 am
rmm200
(@rmm200)
Posted by: @charles-h13
What do you think about these:
https://smile.amazon.com/dp/B07PB399PL?tag=amz-mkt-opr-us-20&ascsubtag=1ba00-01000-org00-win10-other-smile-us000-pcomp-feature-scomp-wm-5&ref=aa_scomp_srdg2
I have a Lack enclosure - and I need to plan for disconnects...
Publié : 06/10/2019 1:47 am
MikiCab
(@mikicab)
Posted by: @robert-rmm200
I am looking at those exact ones right now.  I am just doing my research.  Apparently there are some counterfeits out there than can catch fire.
Publié : 06/10/2019 2:09 am
rmm200
(@rmm200)
The XT60H refers to the 60 amp rating - and the upgraded design. That seems perfect for the Prusa, with margin to spare.
There are a lot of choices - I hope someone does the research and recommends the best one.
Publié : 06/10/2019 2:40 am
MikiCab
(@mikicab)
From what I have read "Amass" makes the best ones but there are counterfeits that can catch fire.  I just bought the ones in the link and will check them out when I get them.
Publié : 06/10/2019 2:49 am
rmm200
(@rmm200)
Posted by: @mikicab
Impatient me - I bought the ten pack too. We can compare notes next week - but I sure like the reviews. Amass - if genuine - looks good.
Publié : 06/10/2019 6:03 am
Milos V.
(@milos-v)
Be realistic. You have a power supply mounted on the enclosure desk, which is almost a paper and you are worried  about 60amps connectors that might catch fire? 😉
I think the soldering will be the important part here.
For the cases that things goes really wrong is there a smoke detector. Sure, the recommendation is not to leave the printer unattended.
Milos
Publié : 06/10/2019 8:30 am
Bunny Science
(@bunny-science)
Also, check how easily the connectors detach once connected. I did one setup with XT60's and ended up never taking the connection back apart. They were darn near impossible to detach once the male and female plugged into each other. Hopefully your Amass ones will be different in that regard.
Publié : 06/10/2019 9:30 am
I'm working with external 24VDC Meanwell PSU since over a year and use this connections (230VAC and 24VDC)  without any problems:
Publié : 06/10/2019 9:45 am
Bunny Science
(@bunny-science)
@  karl-herbert-g What connector is that on the 24 VDC?
Publié : 06/10/2019 9:49 am
www.schurter.ch:
Einbau-Gerätestecker 24V_16A
Publié : 06/10/2019 10:13 am
Membre
I would like to see what others have done.  Mine is ok, but not great.
Publié : 06/10/2019 11:44 am
Milos V.
(@milos-v)
I was thinking of the connectors while making the enclosure, but finally I replaced the original wires with a bit longer ones, that gave me some manipulation space. So if I need to remove the printer from enclosure, I remove it also with PS without disconnecting. Just necessary to unscrew the plastic part on the table, because the wires goes under.
In most cases I just remove the upper part of enclose and leave the printer where it is. Again, longer wires (cable) allows me to move or rotate the printer a bit so I can make most of the maintanance where it stands.
Milos
Publié : 06/10/2019 3:59 pm
MikiCab
(@mikicab)
Posted by: @milo-v
Milos
Look at Yeggi or Thingaverse.  People have mounted these so that the female is mounted and the male can also have a larger case so it is easier to pull out.  I am going to screw the female (Power supply) part to the table and make a larger case for the male to make it easier to pull out.
Publié : 06/10/2019 4:22 pm
MikiCab
(@mikicab)
Posted by: @milo-v
Milos
That is why I am worried about these connectors.  Google Counterfeit XT60's. They catch on fire because they do not make a good connection and get hot. The plastic used in them are not thermal plastic and melts at low temperatures and catch fire.  As you said it is sitting on cardboard table so I am very concerned about these connectors.
Publié : 06/10/2019 4:26 pm
Membre
Posted by: @mikicab
Posted by: @milo-v
Milos
Great stuff.  I am going to use:
https://www.thingiverse.com/thing:985984
or
https://www.thingiverse.com/thing:963344
and
https://www.thingiverse.com/thing:2988989
or
https://www.thingiverse.com/thing:3111628
I have thought about mounting them to the glass.
I have been using the XT30 for my panic wires and XT60 for the power.
Publié : 06/10/2019 6:11 pm
Bunny Science
(@bunny-science)
I too ended up using longer wires without disconnects. Wire is larger 14 gauge, silicone, multi-strand.
Because I frequently work on my printers, I made the wires long enough to allow printer be rotated over 180 degrees or even upside down. Power supply isn't screwed to Lack brackets, but instead held with Velcro strap. If I want to remove printer, the supply quickly detaches from Lack and comes with printer.
Larger gauge wires did require some modified pieces with larger cable channels.
Attachment removed
Ce message a été modifié il y a 6 years par Bunny Science
Publié : 06/10/2019 6:23 pm
Membre
I also looked at Anderson powerpole connectors.
Publié : 06/10/2019 6:29 pm
Milos V.
(@milos-v)
Exactly, I also used wires with larger crosssection to keep the resistance low and not to loose more voltage. I have 2.5mm2 crosssection, that is I think US AWG14. Thanks for sharing the modified plastic parts, I kept the old ones, but it is too tight.
Milos
Publié : 06/10/2019 7:31 pm
Page 1 / 3
