pi to control via internet
Tonino
(@tonino)
Hello guys,
I need you help! 🙂
I'm looking something to check my printer via internet, when I'm not at home. I bought a Pi Zero W and it works... via LAN, but not via web!
I would like to find something to check my printer, pause the print or stop it via internet (ie in case of warping)
Today I usually use an ip-camera to check the printer and a wifi switch to switch-off ...t I would like to upgrade this!
Can any one help me?
Thanks
Postato : 12/06/2020 8:45 pm
1 persone hanno apprezzato
jsw
 jsw
(@jsw)
RE: pi to control via internet
I assume that you are on a more or less standard residential cable or DSL type internet connection. I'm also assuming more or less standard legacy IPv4 addressing on both your outward-facing device and your internal LAN.
I've done this with several devices and yes, one Pi.
It basically involves finding a TCP port that your internet provider is not blocking for incoming connections and doing some configuration on your router to allow the connection.
It also implies that all of your network gear is configured to be resistant to abuse! If you are uncertain on how to do that, I strongly suggest that you do not proceed until you are confident.  Script kiddies are constantly scanning IP blocks for open ports and when they find one they hammer at it looking for such things as weak passwords and known security issues.
Most providers block TCP port 80, the usual web port, for incoming connections on all residential grade connections.  They usually allow many/most of the higher ports.  Pick one.  I suggest that you don't use the usual alternate web ports such as 8080, 28080, etc., as wannabe-hackers concentrate on those and other well-known ports.  Pick an arbitrary one high up in the port space.  45379 would be an example of one that might be a less-unsafe one to use.
Then configure your router to allow an incoming TCP connection on that port.
You have a choice to make.  You can either configure your Pi to respond to that port, or leave it at port 80 and do the translation in your router.
You will need to adjust the rules in your router/firewall to allow the incoming traffic, plus do a NAT (network address translation) to translate the incoming traffic on that port which is destined for your internet-facing IP address to the local IP address of your Pi, which will usually be 192.168.1.x or something similar.  Also, optionally do the port translation.  The better routers allow this.
That's the basic idea.  I know quite a few people using this technique to get incoming traffic from the Internet to their home network devices.
Let me again emphasize. Be VERY careful with your Pi and router configuration.  There are all kinds of script kiddies with too much time on their hands who would LOVE to access your device and (if you're lucky) either just dork around with your local network or worse, use your system for any of several not-so-nice purposes.
I hope this helps, but please be careful!
Postato : 12/06/2020 10:02 pm
Posted by: @antonio-d6
Hello guys,
I need you help! 🙂
Thanks
Maybe you could give teamviewer a try: https://pimylifeup.com/raspberry-pi-teamviewer/
Postato : 12/06/2020 10:54 pm
kirby
(@kirby)
You may get more help on the Octoprint forums. This question and the possible solutions have more to do with Octoprint than the do the printer.
Postato : 13/06/2020 2:50 am
Peter in Katy
(@peter-in-katy)
The Octoprint plugin SpaghettiDetective will do what you need.
You can monitor your print, upload and start gcode, and it will even alert you if it thinks a print is failing. It's not free for the normal installation, but you can set up a local linux box to do all the backend stuff.
You'll also need something with a bit more power than the RPi0.
Postato : 14/06/2020 12:04 pm
towlerg
(@towlerg)
a. take krb's advice - it a good board with lots of patient knowledgeable peeps
b. if you are trying http://octopi.local/ then try just the IP address.
c. Static address are easier to resolve than dynamic. Just a single entry in a text file.
d. if you are using dynamic address, are you running Bonjour?
e. lose the zero, it really is no longer fit for purpose.
Postato : 14/06/2020 12:32 pm
Tonino
(@tonino)
Posted by: @peter-k42
Hello. Thanks... Which one should be fine for the purpose?
Thanks
Postato : 14/06/2020 1:02 pm
kirby
(@kirby)
Thanks
I think the common wisdom is at least a RPi 3B if you're going to be doing anything with streaming video. It only has 1GB of RAM, but I don't think mine has hit the swap space yet, so 1GB appears to be fine. If I were buying new right now I would buy a RPi 4 with 2GB of RAM, just so I could use it for more things in the future. Or, if you're comfortable with this, you can go down the rabbit hole of Raspberry Pi competitors, I haven't tried any of them, but I've heard several are really good value.
Postato : 14/06/2020 2:42 pm
Tonino
(@tonino)
Thanks. I'm looking for solutions. A Pi4 costs about 80€? A netbook 150... But it's almost perfect and can run multiple instances of octopi. Am I wrong?
Which are the comptetior of raspebbery?
Thanks
Postato : 14/06/2020 6:08 pm
kirby
(@kirby)
80EUR is too much. Unless you're talking about a kit with other things in it. Start here:
https://www.raspberrypi.org/products/raspberry-pi-4-model-b/ Select your 2GB and your country. In the US, I can get a 2GB RPi 4B for about 35USD (31-32EUR)  A netbook will almost certainly be more powerful, but it will be bigger and powering it will be a dedicated power adapter or maybe USB-C.
As for competitors, you'll need to do some research to find one comparable to an RPi 3 or 4. One advantage to staying with a Raspberry Pi is the community and support. If you run into trouble or have a question many more RPis are out there in the world. I would only recommend a competitor if either you're following a guide for getting OctoPrint installed and working, or you're comfortable getting a Linux system up and running and have some basic electronics knowledge.
A few competitors I have heard of (I have not tried any of these):
  • Orange Pi
  • Banana Pi
  • ODroid N2
  • RockPro64
  • Nano Pi M4
Again, I really think you'll get better help at the OctoPrint forums, nothing about these questions are specific to Prusa printers, and the folks on the OctoPrint forums have a much wider range of  experience with running OctoPrint in a variety of situations.
Questo post è stato modificato 5 years fa 2 tempo da kirby
Postato : 14/06/2020 7:39 pm
HeneryH
(@heneryh)
This sounds like basic Port forwarding on your home router.  All you need to do is forward incoming Web IP connections to your home router to your OctoPi device.
There are ways to make it more secure such as running a reverse proxy to broker incoming connections but that could be step-2.
Postato : 22/06/2020 3:44 pm
Posted by: @heneryh
No no no! Please read the Octoprint page on securing remote access.
You need to secure your system first, before opening it up. With the probing that goes on these days, an insecure system will be discovered and exploited very quickly. Follow the best practices to avoid heartbreak.
Postato : 22/06/2020 5:18 pm
HeneryH
(@heneryh)
Yes, devices get probed all of the time.  But a Raspberry Pi running a modern web browser with user credentials should be on the safer side as compared to a WebCam with default admin/admin credentials.
To each his own, I am running a reverse proxy behind an Nginx/Ubuntu VM that brokers all of my inbounds and have a mix of user credentials and user certificates.
People get into religious battles when it comes to this.  Some will say VPN is the only way to go.  Some say a Reverse Proxy is preferred.  Some say a modern web browser on a modern OS with user credentials is OK.  Nobody should ever say that default credentials or an unknown Chinese IoT device is OK.
Postato : 22/06/2020 5:25 pm
jsw
 jsw
(@jsw)
At least the current Raspberry Pi makes you change the default password.  For a long time, that was not enforced, and it's amazing how many of them are out there with defaults.  🙁
Postato : 22/06/2020 5:40 pm
@bobstro
Maybe this could ba an interesting article for you 👍 https://www.zdnet.com/article/thousands-of-3d-printers-may-be-leaking-private-product-designs-online/
Postato : 22/06/2020 6:06 pm
Posted by: @heneryh
Please note that I linked to the official Octoprint guidelines as put forth by the developer
That sounds great. I was just alarmed when I read "that could be step 2". Unfortunately, it always seems to get put off until something unfortunately happens.
The problem I see in a lot of the 3D printing (and other) groups is that new users get enthusiastic about something, implement it without understanding the risks thinking "nobody will notice" and are often surprised when someone notices within hours. Unfortunately, fingerprinting raspberry pis is one of the top scanning activities these days, so obvious ones (default ports, accounts) get sniffed out quickly. If you're at the point of doing ssh, reverse proxy or VPN, you're ahead of most of the new users at least!
Postato : 22/06/2020 6:40 pm
Posted by: @karl-herbert
@bobstro
I believe that's the same incident that Gina refers to on the Octoprint page. She was not happy to find herself defending the security of a package that was never meant to be exposed to the internet in the first place.
Postato : 22/06/2020 6:41 pm
HeneryH
(@heneryh)
OK, you want people who don't even take the time to create/reset user credentials to perform even more complex tasks?  Sure.  I read that article and expected to find some undisclosed vulnerability to be the culprit.  Nope.
I consider basic user hygiene table stakes but I suppose I could be more explicit in my comments in the future.
Postato : 23/06/2020 1:32 am
