Parts modified for Igus bearings
Chastain09
(@chastain09)
Does anybody have adjusted X-End-Engine, X-End-Idler, X-Carriage, X-Carriage-Back changed STL for Igus RJZM-01-08 (Aluminum housed) bearing? they are marginally bigger than LMUs at 15.98 mm.
Much obliged to you!
walgreenslistens
Posted : 29/09/2021 11:02 am
Dan Rogers
(@dan-rogers)
Nope. Use the un-housed ones with no changes.
I have two printers with the "regular" plastic Igus bearings.  For the MK3s, I had to modify the Y carriage clips (downloaded from prints library) - but for the MK3S+, no changes were needed at all.
Posted : 30/09/2021 6:43 am
Tomson Design
(@tomson-design)
X-Carriage
Hi Chastian09. Sorry for late answer. I have made a X-Carriage for IGUS Partnr:RJZM-01-08. https://www.prusaprinters.org/prints/68537-mini-bear-remix-and-spoolholder-and-filament-feede .   I have also made a new Extruder with both OEM and IGUS bearings for 40x20mm Noctua fans. I have tested the mirrored one for MINI-Bear for a couple of weeks now with good results. And i´m now doing the last tests for MK3 and Mk3-Bear. https://www.prusaprinters.org/prints/77810-mk3-hurricane-extruder . But for the Hurricane extruder to OEM MK3 i have make some small changes since i upload them. If everything feels good in the test i gonna upload the last changes later tonight.  Regards/Tomson
Posted : 10/10/2021 9:43 am
