Octopi/Octodash settings
Krushy
(@krushy)
So I recently got around and fixed a pi 3b+ and installed octopi on my mk3s with the mmu2, and after 2 weeks of playing around with it I decided to add the 7" screen to the pi (the official screen).
Now to my problem, I'm a little of a novice and when I decided to install octodash I got everything wokring fine, it all boots up as it should but then it gives me the setup screen, I've tried to google and ask in the FB group but I can't for the life of me find the information. Octodash is asking for Feed Lenght and Feed Speed, does anyone run this combo and what should I put in as feed lenght/speed?
I know it might be a dumb question since it should be easy to know the answer but I'm stuck at this somehow.
Thanks in advance, Simon Aka krushy.
Posted : 25/03/2021 7:39 pm
senatorface
(@senatorface)
RE: Octopi/Octodash settings
You've probably gotten past this by now, but you can set it to 60mm and the default speed that's in there. It ultimately won't matter, since MK3S supports the M600 command for filament reload, and OctoDash now has an option to use M600 instead. So set it to 60mm and 20mm/s speed, then in the settings once you're in enable "Use M600 to change Filament".
Posted : 30/03/2021 9:27 pm
Jeff
 Jeff
(@jeff-10)
thanks Jessie !
Posted : 13/02/2022 4:25 pm
