Nylock Mod bumpy bed
Hi, I recently did the nylock mod to combat the bed's "unflatness"
I now have the problem that my bed seems to have 4 bumps and I don't know what to do:
the Pinda Values are:
0.16333 0.20250 0.17417 0.16000 0.20500 0.19750 0.16833
0.23250 0.27417 0.24667 0.20000 0.25083 0.27000 0.21250
0.18000 0.25250 0.22583 0.20333 0.22833 0.24417 0.17417
0.16083 0.21083 0.19083 0.15917 0.19729 0.20583 0.15583
0.20167 0.23667 0.22583 0.19396 0.19583 0.23167 0.17083
0.19250 0.24500 0.24083 0.19500 0.21583 0.23667 0.16750
0.13667 0.17167 0.19583 0.15333 0.19250 0.20250 0.16083
help would be appreciated ^^
RE: Nylock Mod bumpy bed
Is it really that bad or is it just the way it is show that makes it look bed. The difference between the lowest and highest point is only 0.1375 mm (I guess those are mm)
Is this with the bed at printing temperature?
What did you use to get the picture? I have only seen these with a scale going from -2 to 2.
the diagram is strongly exaggerated, but I still have these height differences. I did the measurement at 60°C bed temp. I used this site for the diagram: 3D Printer Auto Bed Leveling Mesh Visualizer – lokster | space (lokspace.eu)
If 0.1375mm are fine then I don't have a problem I guess? but I'm still curious about why this pattern happens to me.
I put in my numbers from sending a G81 via octopi.
This is what I got. max difference is 0.11 mm for me. And looks a lot like yours. All my prints come out fine. Even ones that almost fill the entire bed.
I wouldn't worry if the prints are fine.
