Next Review / Test: Steel Sheet Beds
Page 1 / 2
Membre
There are a number of spring steel sheets wyou can buy aftermarket to add to you printer.
I have a few that I recently purchased from China and will be posting photos. I will post a photo of each as I test them. They range in price from $11 to $25. Some look like copies of the Prusa bed.
Publié : 22/10/2018 3:00 am
Re: Next Review / Test: Steel Sheet Beds
Please post links for purchase! Thanks.
Publié : 22/10/2018 3:09 am
Membre
Linsk will be coming soon. If you happen to find one you want to be tested, please post one also.
Publié : 22/10/2018 3:17 am
Every bare sheet I've found costs nearly as much as a genuine Prusa with double-sided PEI already applied. I've got 2 of the Prusa sheets, but would like a cheap blank just to experiment with. BuildTak is as close as I've found at $25.
Publié : 22/10/2018 3:41 am
Membre
I will post links. I have found a couple that are cheaper.
Publié : 22/10/2018 4:05 am
Any update on these links?
Publié : 08/11/2018 3:43 am
surfgeorge
(@surfgeorge)
Found and ordered on Aliexpress:
https://www.aliexpress.com/item/Reprap-i3-Mk3-Mk52-Spring-Steel-Sheet-Heat-Bed-Platform-3D-Printer-Printing-Buildplate-For-Prusa/32948155660.html?spm=a2g0s.9042311.0.0.3da24c4d8pAqBT
Combined with this print surface from the same vendor
https://www.aliexpress.com/item/1pc-Prusa-i3-MK3-MK52-Sheet-Heat-Bed-Platform-3D-Printer-Buildplate-Black-Sticker-Sheet-For/32901822760.html?spm=a2g0s.9042311.0.0.3da24c4d8pAqBT
it comes to nearly the same cost as an original Prusa flex sheet, but I want to have a BuiltTak surface for Nylon and Polycarbonate
Waiting for whipment, will report
Publié : 08/11/2018 9:12 am
RH_Dreambox
(@rh_dreambox)
He he, Chinese are fun. Note that you can not print on that print surface 😆 😆 😆
Publié : 08/11/2018 9:23 am
Membre
I have each of these and they they are good quality. I will post a review of th sprint surface next week.
Publié : 08/11/2018 7:35 pm
stephen.h14
(@stephen-h14)
It looks like they just don't want you to print the letter "J"? Anything else should be ok. Not sure what the Chinese have against the letter J? 😯
Publié : 09/11/2018 2:47 am
Membre
So many options for spring steel sheets, I have Buildtak, Blurolls, FYSETC, and ENERGET. I am sure there are more.
Publié : 11/11/2018 6:39 pm
Links? I found BuildTak and the Aliexpress link you provided before, but I'm curious about the others. I haven't had much luck searching.
Edit: Ah, looks like they're all on Alixpress! I didn't have the names before, so never got hits. They're pretty blatant copies. How is the quality on the cheap ones? Are they truly flex steel?
Publié : 11/11/2018 7:46 pm
Membre
I will start reviewing them this week with a link to each product. I have to clean one. I put a piece fo blue PEI on it and need to remove the adhesive.
The blue PEI was too "sticky" and I could not remove the print from it. It ripped. The bed if fine but I need to remove the adhesive and add another surface.
Publié : 11/11/2018 8:07 pm
Pathogen
(@pathogen)
This appears to be related to drug use, a warning not to have a "J" when using these advanced technologies, which surely is good advice! 😎
Publié : 14/11/2018 5:22 pm
Membre
I will post some pictures and links tonight.
Publié : 14/11/2018 6:14 pm
Membre
Ok, I have found basically 3 Chinese made products. It took me a little time to find them with some creative searching.
Publié : 15/11/2018 2:16 am
Membre
The first bed I purchased to test was the Energetic which is a plain steel bed. I am going to put prusa PEI on it to test once I get my next order.
Links:
https://www.aliexpress.com/store/product/ENERGETIC-Prusa-I3-Mk3-Mk2-5-PEI-Buildplate-Spring-Steel-Sheet-Heat-Bed-Platform-3D-Printer/4542004_32926957643.html
https://www.aliexpress.com/item/ENERGETIC-Upgrade-Prusa-MK2S-Heatbed-With-Removable-Spring-Steel-PEI-Sheet-224x254mm/1000006844087.html
I paid $13.73. The prices goes up and down.
Publié : 15/11/2018 2:22 am
toaf
 toaf
(@toaf)
did they really label it 3D MAX? I'm telling autodesk
Publié : 15/11/2018 2:27 am
Membre
The FYSETC spring steel sheet. You can buy them with PEI and without. The key is searching Aliexpress and looking for the lowest price and free shipping.
Links:
  • Aliexpress1
  • Aliexpress2
  • I paid about $19 but recently foudn them significantly cheaper. Keep searching because black friday is coming.
    Publié : 15/11/2018 2:41 am
    Membre
    Blurolls sprign steel. I have 3 of these. I bought 2 for $12 a piece and they have a mirror like finish. I bought another and it was $14.86.
    These are very similar to the next bed I bought, but without lines.
    Links:
  • Aliexpress1
  • Aliexpress2
    Publié : 15/11/2018 2:53 am
    Page 1 / 2
