My $26 enclosure, no assembly!
GBelfor
(@gbelfor)
Hey all.  I wanted to try printing a few things inside an enclosure but without spending lot of time and expense.  Turns out this item at Amazon fits perfectly, gives you pretty good visibility, and it's a cheap and easy way to give it a shot. It's supposed to be a mini-greenhouse to cover a plant in a pot.
If it helps your prints, then move on to a more "classy" enclosure.  OR, if you're like me, just keep using it as-is!  My printer has an MMU, but the enclosure works just fine with the MK3 as well...plenty of headroom for the filament spools on top inside the tent.
https://www.amazon.com/dp/B07HP4Y8T6?psc=1&ref=ppx_pop_dt_b_asin_title
Posted : 20/11/2021 9:43 pm
Dan Rogers
(@dan-rogers)
And you're good when a pipe breaks!
Looking fashionable there...  How are you filtering?
Posted : 21/11/2021 6:56 am
PenguinNinja
(@penguinninja)
RE: My $26 enclosure, no assembly!
I like the thinking. Inexpensive and serves the purpose just fine.
Posted : 29/01/2022 1:21 am
