Mosquito - Clearing a heat creep jam easily
Bunny Science
(@bunny-science)
Although the Mosquito hot end is known to reduce heat creep and jams associated with that issue, it is not completely immune to heat creep jams. If you ever let the Mosquito's heat sink cooling reduce while the hot end is still hot, you will get a very solidly stuck filament. Fortunately, the Mosquito can do a trick that you can't with a heat creep jammed E3D. A mosquito can melt itself free if you let it heat while blocking the hot end fan.
Release idler tension so you can manually feel and move the filament.
Set nozzle temperature to your filament's usual printing temperature
Block airflow going into the hot end fan (the Noctua on left) with a piece of cardboard. This causes melt zone to go above the normal heat break region. Don't do this for more than maybe two or three minutes or you risk melting stuff that should not melt.
As the melt zone is being expanded by lack of airflow, gently try to move the filament. Eventually, the filament will move.
Push filament downward with your fingers and extrude a few cm
Do a pull / push ramming motion to fully clear plastic from above the heat break transition zone
Finally pull filament out
Let airflow go back to normal.
Your jam is cleared without taking apart the hot end, extruder or pulling PTFE tube like you would with an E3D.
Opublikowany : 25/06/2019 5:17 pm
5 ludzie polubili
Lopatka
(@lopatka)
RE: Mosquito - Clearing a heat creep jam easily
I want to thank you!  I had a print that broke free from the bed, and of course I hit reset to quickly stop the print since I sent the file through Octoprint and would take too long to boot up my laptop.  The fan stoped for a minute and created a jam that I thought was hopeless.  After nearly giving up, I decided to do a quick search and came across your post.  Sure enough it worked.  Again, thank you!!
Mark
Opublikowany : 26/11/2019 7:26 pm
Bunny Science
(@bunny-science)
Happy the tip helped someone out.
Opublikowany : 27/11/2019 12:15 am
Vumelyan
(@vumelyan)
I had the is fortune to have the filament break right at the bondtech  feed  gears and I think the plastic is heat creep/seized up in the copper and ptfe part of the hot end.  Should I just try to take apart the hotend to find out where it's lock up?  Hopefully I haven't trashed the nozzle/heatbreak or the copper cold zone tube.
Opublikowany : 10/01/2020 4:14 am
DDubyah
(@ddubyah)
@tfsyth
Ive just had exactly the same problem. Filament snapped right at the gears. Any tips on how to fix it?do I have to dismantle the whole thing? Any advice would be greatly appreciated.
This post was modified 6 years temu by DDubyah
Opublikowany : 01/08/2020 6:45 am
I made huge mistake.  I heated my Magnum up to PC Blend temperatures and unloaded the filament.  Mine is jammed all the way up now.  I will have to try to unload it.  I will try this, wish me luck.
Opublikowany : 01/09/2020 5:51 pm
Hesham Eissa
(@hesham-eissa)
You're a rockstar. Was trying to think how I can heat up the cold end without disassembling and your cardboard trick is just genius. Thank you!
Opublikowany : 25/10/2020 5:19 am
BarrittWorks
(@barrittworks)
Yep, that trick is genius.
I switched to some relatively hard TPU after printing PETG and was too aggressive in feeding the TPU in during the switch (at a slightly lower temperature than I'd have the hot end for PETG). Some retraction and then re-insertion of the TPU and the result is a bunch up of TPU above/in the heat break that cooled. Totally jammed Mosquito.
This trick allowed me to pull the offending block out the top after a minute or two of heating with the fan blocked.
I'll add one adjustment: I used a small sticky note to block the fan instead of a piece of cardboard. Worked perfectly.
Thanks!
Opublikowany : 28/07/2022 1:34 am
Nick Cent
(@nick-cent)
I'm fed up with the mosquito. Heat creep at another level!  And today the thread has been damaged and no nozzle will screw in. One month ago I replaced the hotend! Not buying into anything you might have to say. I'm talking by experience with this shiz. no more bs thanks.
Posted by: @bunny-science
Opublikowany : 06/06/2024 2:04 pm
