MK3S+ printed parts on MK3S
I like the looks of the + printed parts, especially the fan shroud improvements as my current fan shroud seems to warp a bit in use. Is it possible to transplant all the MK3S parts into the 3S+ printed parts or are the new superpinda and filament sensor required?
RE: MK3S+ printed parts on MK3S
I simply printed all the Mk3S3+ extruder parts to rebuild the hotend/extruder on my Mk3S. The filament sensor has not changed and can simply be moved over. I had already upgraded the Pinda to a Superpinda so moved that one over. But I don't see a reason why you couldn't use the original Pinda though. Should fit the Mk3S+, I don't think there's a change in form factor.
@fuchsr
Thanks, I'll print them out then have fun over the weekend with the upgrade.
