mk3 won't start with Raspberry Pi installed
Brendan
(@brendan-3)
I'm having trouble getting Octoprint to work on my mk3.
I bought a Raspberry Pi Zero W and followed the instructions ( http://manual.prusa3d.com/Guide/0.+Preparing+necessary+components/585 ) to set up PrusaPrint and solder the headers. Everything seemed fine, but when I plug it into the EINSY board my mk3 won't start up.
The first time I powered it on with the Pi installed it never went beyond the startup screen, and every time after that I just get a blank screen at startup. I tried it with the RPI port enabled and disabled. The printer appears to start normally if I remove the Pi, but it always locks up with the Pi installed.
Postato : 09/04/2018 9:34 pm
Dan
 Dan
(@dan-13)
Re: mk3 won't start with Raspberry Pi installed
Would you mind posting a picture of the pi (either plugged in or by itself)?
Postato : 11/04/2018 6:22 pm
sowa
 sowa
(@sowa)
RE: mk3 won't start with Raspberry Pi installed
Hopefully this topic isn't dead completely, due to I have the same problem.
I set up a Pi Zero W and also connected to it when it was not installed to my MK3s. When I connect it to the EINSY, the printer does not start. I activated the pi port before I plugged the pi in. Maybe some could help me? I attach some pictures of the pi and the lcd screen
Postato : 10/09/2020 5:37 pm
@sawo
@brendan-s4
I would connect the Pi Zero without Einsy to a 5V voltage (power supply or powerbank) and check if it boots without any problems and to be on the safe side, also check all soldered joints for short circuits with a magnifying glass.
Postato : 10/09/2020 11:00 pm
gmaayan
(@gmaayan)
Was there every any resolution to this problem? I'm getting the same thing.
Postato : 01/02/2021 2:40 am
sowa
 sowa
(@sowa)
@gmaayan
In my case i solded the pins wrong to the RPI. You can see it on the pictures. I had two pins next to each other where only should be one. After fixing it I changed the Zero to a 3b+, because the zero is very slow.
Postato : 01/02/2021 12:13 pm
@gmaayan
I would also be interested, but unfortunately there is no feedback on this yet.
If the Pi Zero is connected correctly, it can really only be the Pi itself or the installed image. Prusa offers a customized and optimized image for the Zero: https://help.prusa3d.com/en/article/prusaprint-rpi-zero-and-octoprint_2180/
Postato : 01/02/2021 12:25 pm
im
 im
(@im)
Utenti
The same issue occurred on my MK3S+ with a Raspberry Pi Zero 2 W. After around three months of normal operation one day they both failed to start and the LCD also showed two rows of white squares.
The problem seemed to be a faulty connection on one of the GPIO pins. I resoldered all of the headers on the Pi, applying quite a lot more solder than before, and afterwards they both worked normally again.
Postato : 13/05/2025 5:07 pm
