Mk3 + 0.8mm nozzle
Seite 5 / 5
OurAngryBadger
(@ourangrybadger)
Re: Mk3 + 0.8mm nozzle
Anyone have 0.8mm profiles to share?
Veröffentlicht : 26/10/2018 9:16 am
You're welcome to my config bundle here. Let me know if you just want specific profiles.
Veröffentlicht : 26/10/2018 2:23 pm
ukash
(@ukash)
Thank you for sharing! 🙂
There is post processing script (print settings->output option):
/Users/bob/Documents/Shared/Slic3r/slic3r_massage.py;
Is there something interesting? Throwing error because of this fixed path 😉
Veröffentlicht : 22/12/2018 2:03 pm
xhillb61
(@xhillb61)
Bob, thank you for sharing!!!
Veröffentlicht : 22/12/2018 2:56 pm
[...] There is post processing script (print settings->output option):
Ah, sorry about that. Just blank the post-processing script out under Print Settings->Output options->Post-processing scripts for now. It's a python script that mostly appends the print time estimate to the filename after slicing. I'll put a link and a description up soon, just a busy time. It is written in python, so you'll need to have python running on your system to use it.
Veröffentlicht : 24/12/2018 3:03 am
neil.s4
(@neil-s4)
Thanks for sharing Bob, a lot of work.
What is the change I need to make to load these profiles for MK3 MMU2 single?
Veröffentlicht : 26/12/2018 11:54 pm
Hrouda
(@hrouda)
Mitglied
RE: Mk3 + 0.8mm nozzle
Posted by: @lukasz-l2
Veröffentlicht : 04/10/2024 7:02 am
Seite 5 / 5
