Re: Mk3 + 0.8mm nozzle
Anyone have 0.8mm profiles to share?
You're welcome to my config bundle here. Let me know if you just want specific profiles.
Thank you for sharing! 🙂
There is post processing script (print settings->output option):
/Users/bob/Documents/Shared/Slic3r/slic3r_massage.py;
Is there something interesting? Throwing error because of this fixed path 😉
Bob, thank you for sharing!!!
[...] There is post processing script (print settings->output option):
Ah, sorry about that. Just blank the post-processing script out under Print Settings->Output options->Post-processing scripts for now. It's a python script that mostly appends the print time estimate to the filename after slicing. I'll put a link and a description up soon, just a busy time. It is written in python, so you'll need to have python running on your system to use it.
Thanks for sharing Bob, a lot of work.
What is the change I need to make to load these profiles for MK3 MMU2 single?
RE: Mk3 + 0.8mm nozzle
/Users/bob/Documents/Shared/Slic3r/slic3r_massage.py;Is there something interesting? Throwing error because of this fixed path 😉
