Is the 24v volcano heater block the correct match for the I3 MK3?
Seite 2 / 2
MTJC
 MTJC
(@mtjc)
Re: Is the 24v volcano heater block the correct match for the I3 MK3?
btw, if anyone wants to see the heater cartridge going through the heaterblock like it's a piece of cheese, look here:
Not all it appears to be; he is putting more than 100W into that heater block (19 Volt, 3.6 Ohm, 5.2Amp)
Peter
How do you know this Peter? Thx.
Veröffentlicht : 16/03/2019 4:46 am
richard.l
(@richard-l)
Mitglied Moderator
Peter
Ohm's Law. A 12v 40W heater has a resistance of 3.6 ohms. Therefore, when applying the 19v to the same 3.6 ohm resistance you get 100w.
Veröffentlicht : 18/03/2019 3:35 pm
CybrSage gefällt das
Mustrum Ridcully
(@mustrum-ridcully-2)
Peter
And you can expect a somewhat shorter life of the component heater I would expect
Veröffentlicht : 18/03/2019 5:10 pm
MTJC
 MTJC
(@mtjc)
Thanks!
Veröffentlicht : 21/03/2019 7:02 am
richard.l
(@richard-l)
Mitglied Moderator
Thanks!
No problem! I have been vaping for 10 years so I am intimately familiar with Ohm's law.
Veröffentlicht : 21/03/2019 2:22 pm
MTJC
 MTJC
(@mtjc)
Veröffentlicht : 21/03/2019 4:54 pm
JoTa
 JoTa
(@jota)
RE: Is the 24v volcano heater block the correct match for the I3 MK3?
Posted by: metacollin
Oh, you will probably need to recompile the firmware and reduce #define Z_MAX_POS = <...> in the Configuration_prusa.h file by about 9mm (the volcano is 8.5mm longer than the v6).
No other modifications are needed, and after that firmware change, your MK3 will never even know the difference.
how doI recompile firmware? Im not an IT/ computer guy, so try and keep the explanations simple....
Veröffentlicht : 02/05/2019 5:49 pm
JoTa
 JoTa
(@jota)
Am i missing something? where is the attachment?
Veröffentlicht : 02/05/2019 9:17 pm
Seite 2 / 2
