Has anyone upgraded to the Bondtech Extruder and what has been your print quality experience?
Crunch
(@crunch)
Please share your print quality after upgrading to the Bondtech Extruder is it worth the time Bondtech BMG Prusa MK3S/MK2.5S v2
Bondtech Upgrade Kit For Prusa i3 MK2.5 & MK3
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Opublikowany : 26/10/2019 7:28 pm
RE: Has anyone upgraded to the Bondtech Extruder and what has been your print quality experience?
I bought the Bondtech for Mk3s and I am happy with it.
Opublikowany : 27/10/2019 2:47 am
I built my own mix of MK3 and BT Extruder with fast and easy hotend change possibility: https://grabcad.com/library/prusa-mk3-bt-1-8-extruder-1
..with slightly better print results by reducing ghosting and vibrations for a more homogeneous surface, similar to these pictures:
wbr
Opublikowany : 01/11/2019 8:46 pm
ManelTo
(@manelto)
to the MK3S do you only need the upgrade or is it necessary something else? Like a new firmware or another hardware.
With the bear upgrade is it work?
Sorry for my poor English. I try to do my best.
Opublikowany : 01/11/2019 9:53 pm
Posted by: @manelto
The bondtech has a firmware upgrade.
Opublikowany : 02/11/2019 1:04 am
Look here: https://www.bondtech.se/en/product/prusa-i3-mk3s-extruder-upgrade/#tab-firmware
(Estep set to 830; adjusted Z_MAX_POS to 205; changed printer name).
For the Bondtech Upgrade You need a new x-carriage. You can find all files and information on the Bondtech sides.
Opublikowany : 02/11/2019 1:43 am
Ido
 Ido
(@ido)
@mk3betatester did you do the upgrade?
Im thinking about getting the upgrade, all looks good. One thing I am a bit hesitant about is the need of another firmware. I will be dependent on Bondtech, So 1 year from now, when Prusa releases version x, will bondtech still update it as well?  Is the firmware update the only method, or can it also be done through GCODE or the CLI?
Opublikowany : 26/12/2019 8:42 am
I have it and have used it for about 4 months.  I like it.  The firmware is easy to install and is updated regularly.
Opublikowany : 26/12/2019 11:59 am
@ido-d
I did my own upgrade. You can edit the sourcescript, which you can find on the Github sites, compile it and flash with PrusaSlicer.
Here an example (my MK3S with 1.8 stepper extrudermotor) with optional changes:
Bondtechstepper-Einsy_Rambo_1.1a
Opublikowany : 26/12/2019 2:19 pm
C.R. Brown
(@c-r-brown)
Excuse the ignorance but these Extruders should work fine with the MMU2 kits correct? I've lost a single gear shaft lock and to replace that one part in cost has me looking at a whole new extruder for just a wee bit more.
Opublikowany : 03/04/2020 1:19 am
@christopher-b23
Hi Christopher,
do you mean that you have lost the Grub Screw?
it's a 2mm long, M3 Grub Screw...
Check the magnets under your heatbed. a number of people have found the grub screw stuck to the magnets,
alternatively have a look in your spare parts bag, that came with the printer kit... that should contain a spare.   (Note, there should also be a 3mm M3 grub screw in the  spare parts bag too... this is too long for the Bondtech gear, it will cause jamming...
Opublikowany : 03/04/2020 6:16 pm
C.R. Brown
(@c-r-brown)
@joantabb
Yes I believe it is! Thank you for the correct name. Thats much easier to replace than the gear and cheaper!
Opublikowany : 03/04/2020 10:27 pm
prusanewuser
(@prusanewuser)
Is the Bondtech extruder upgrade for the MK3S still working great? After all these months, is it still better than the stock extruder which came with the i3MK3s?
Opublikowany : 03/09/2020 11:10 am
MileHigh3Der
(@milehigh3der)
I'll necropost this one in the hope to get the long term feedback from people that had them.  I have a Mk3s/MMU2s that I'm going to upgrade to a REVO high temp version.  I'd like a bit better extruder and was looking at the Bondtechs.  I'll probably remove the MMU2s and run it singular, in a PRUSA enclosure.
Any thoughts on upgrading using a REVO and a new exrtuder?
Opublikowany : 25/10/2023 9:41 pm
ChrisG
(@chrisg)
When I look at the Bondtech firmware page, At the to 'mainboard version (eg: RAMBo10a; RAMBo13a; EINSy10a;...)' Nu buddy board. Or do I miss something?
Posted by: @karl-herbert
Opublikowany : 01/03/2024 11:51 am
