Extruder Stepper Coolingfan always running
Tech4You
(@tech4you)
Hey!
Just started to mod my mk3s with https://www.thingiverse.com/thing:2975582 and wanted to check where I should connect my 5v fan. Yes i know i can connect it up in the right corner but i only want it to run while I am printing. Just like the hotend fan.
Any ideas?
Napsal : 04/08/2020 2:57 pm
RE: Extruder Stepper Coolingfan always running
connect the red and black of the new fan to the cold end fan wire run them in paralellķ
Napsal : 04/08/2020 3:23 pm
Tech4You
(@tech4you)
@joantabb
So I can connect it to the left hotend fan output and not slowing down the hotend fan?
Napsal : 04/08/2020 3:32 pm
@nilssonandy
the hot end fan FET is powerful enough to power two fans, in paralell...
as long as they are both 5Volt fans you will be fine!
Napsal : 04/08/2020 6:51 pm
Peter M
(@peter-m)
5 volt, you could also use a phone charger, and keep this separate from the 3d printer.
Napsal : 05/08/2020 7:22 pm
