Changing nozzle question
Fotoman
(@fotoman)
The instructions from Prusa say to make sure there is no filament left in the hot end before changing the nozzle. How does one do this. If I remove the filament, there always appears to be a little left in the nozzle (maybe I am wrong, but that is the way it looks). Will high heat make it drip out? Some other way of making this happen?
Proud owner of a Mk3 that is producing very nice prints. There is room for improvement as I learn more about it, but so far I am very happy.
Posted : 30/04/2018 11:49 pm
Nikolai
(@nikolai)
Re: Changing nozzle question
You're correct. In the nozzle is still something. By hotend is usually meant the whole head as a unit. Maybe "Unload any loaded filament from the hotend" will be a more accurate verbiage.
Dripping out is not a valid option. It might get burned in the nozzle.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 01/05/2018 12:10 am
chad.k
(@chad-k)
The best way I've seen to cleaning out a nozzle before replacing it was doing a 'cold pull'. It ensures that the nozzle is completely evacuated, but works best with nylon filament. A single pull (provided it produces a proper outline of the nozzle) is enough to empty it. The process requires a fair bit of force, so be very careful and patient or you might break something.
These two pages describe it pretty well (they're for other printers, but the process is fairly universal):
http://bukobot.com/nozzle-cleaning
https://printrbot.zendesk.com/hc/en-us/articles/202100554-How-to-Unclog-the-Hotend-The-Cold-Pull
Posted : 02/05/2018 5:18 am
rob.l6
(@rob-l6)
Nozzles are so cheap and once you've done it a couple of times, pretty quick to change out. I think it's easier to replace than worry about trying to clean/restore them.
Posted : 02/05/2018 5:37 am
PJR
 PJR
(@pjr)
Antient Member Moderator
+1
When you get into the habit of cleaning nozzles, you spend more time cleaning than printing.
As soon as I get nozzle problems, swap it out. I have a very dusty environment, so I change nozzles about once a month. Also why I don't use exotic nozzles..
Peter
Posted : 02/05/2018 12:56 pm
Chileo
(@chileo)
+1
Peter
What do you normaly use for replacement nozzle? The ones from Prusa?
Posted : 02/05/2018 4:19 pm
GertL
(@gertl)
I buy mine from E3D
https://e3d-online.com/nozzles-for-3d-printer/v6-nozzles
Gert
Posted : 02/05/2018 4:36 pm
PJR
 PJR
(@pjr)
E3D direct, just like Gert.
Peter
Posted : 02/05/2018 5:50 pm
Fotoman
(@fotoman)
Thanks for all your help and suggestions. I ended up just unloading the Filament and then heated the nozzle to 285 degrees, removed the old nozzle and replaced it with an Olson Ruby with the tool as per their instructions.
Thanks again
Posted : 02/05/2018 7:11 pm
rob.l6
(@rob-l6)
Well, some may shudder at the thought but I bought some off eBay (J-Head brand) to try out. I have to say that I have not noticed any difference in print quality. However, the risk here may be quality control, you may get a few baddies in the bunch. But when they cost literally cents ...
Posted : 03/05/2018 3:51 am
GertL
(@gertl)
I can recommend below tool for swapping the nozzle.
Its very easy to bend the hotend putting to much force sideways (been there).
https://support.3dverkstan.se/article/66-the-olsson-ruby-instructions-for-use
Works very well and you will see that you do not need to tighten so hard.
Gert
Posted : 03/05/2018 8:41 am
