Can't get the webcam to work with Octoprint.
Seite 2 / 4
BillR94
(@billr94)
RE: Can't get the webcam to work with Octoprint.
Hmmm I don't understand why it won't open. I am reading using Notepad ++.
Can I just copy and paste that text to the bottom of the Octopi.txt file?
I got my Zero 2 W off of Amazon.
https://www.amazon.com/dp/B0CCRP85TR?psc=1&ref=ppx_yo2ov_dt_b_product_details
Veröffentlicht : 05/10/2023 6:56 pm
BillR94
(@billr94)
I think it is the 1.7.something. I'll try the 1.9.2
Veröffentlicht : 05/10/2023 6:58 pm
Walter Layher
(@walter-layher)
Which text do you mean? But I don't think any changes to the octopi.txt are necessary for this. I suspect you used the image version with the old camera stack, that is a bit different and I think you have to add or uncomment something for the camera type. The newer version with the new camera stack does not need this. Please try the new one from the link I posted a few minutes ago. The newer camera stack is supposed to become the version that will be supported in the future, so changing to that is better and recommended anyway.
Veröffentlicht : 05/10/2023 7:01 pm
Walter Layher
(@walter-layher)
Ah yes, that could be the reason. The new version is this: OctoPi 1.0.0 with OctoPrint 1.9.2 (build 20230718115729 from branch camera-streamer)
Veröffentlicht : 05/10/2023 7:02 pm
BillR94
(@billr94)
ok...doing it now. Thank you
Veröffentlicht : 05/10/2023 7:04 pm
Walter Layher
(@walter-layher)
Amazon prices for Raspberrys have been rather high here if they were available at all (Zero 2 W, I mean). I prefer to buy them from official distributors in my region and they are all out.
Veröffentlicht : 05/10/2023 7:05 pm
Hello
(@hello)
Posted by: @walter-layher
They have s bunch at the store near me all pies zero w zero 2w pi3b+ an pi 4 at cheap prices and I'm in nz we normally get stuff last so they seem to be coming back in
Veröffentlicht : 05/10/2023 7:09 pm
Walter Layher
(@walter-layher)
Just dig a hole and throw them in, they should pop out around here somewhere ... 🙂
Veröffentlicht : 05/10/2023 7:11 pm
Hello
(@hello)
Haha sure 🙂
Veröffentlicht : 05/10/2023 7:18 pm
Walter Layher
(@walter-layher)
The other types you can all get here, but no Zero 2 Ws. I don't need one absolutely and immediately right now, but it would be nice to upgrade my existing projects that use Zero Ws. I still have spares of the bigger ones.
Veröffentlicht : 05/10/2023 7:25 pm
Hello
(@hello)
Can I ask what you do with them I've got a spare I want to use in a project
Veröffentlicht : 05/10/2023 7:29 pm
Hello
(@hello)
I presume your in the US if so Sparkfun has them https://www.sparkfun.com/products/18713
Veröffentlicht : 05/10/2023 7:32 pm
Walter Layher
(@walter-layher)
I am in Germany. I use the Zeros for MotionOS, bird feeder cam, nesting box cam, another one is in a cubotino, one is in a pwnagotchi. The Pi4s are for OctoPrint, Pihole, Tiny Pilot KVM, PiKVM. The KVMs are for monitoring and setting up of headless homelab PCs with Proxmox or other headless computers, you can even set up another headless Pi with them. 🙂
Veröffentlicht : 05/10/2023 7:45 pm
Hello
(@hello)
Ah thought you were in us thanks for the project ideas
Veröffentlicht : 05/10/2023 7:47 pm
BillR94
(@billr94)
OK ... I install the 1.9.5 and the camera now works. However, I can't get any of the plugins. It says I need to connect octoprint to the internet. I thought I was as I inputed the SSID and password for the wifi? See attached.
What am I missing here?
Diese r Beitrag wurde geändert Vor 2 years von BillR94
Veröffentlicht : 06/10/2023 3:18 am
Walter Layher
(@walter-layher)
Hey, nice that the webcam is working now! 🙂
Did you activate the connectivity check in the installation wizard or did you skip it?
Can you log into the pi via ssh? This should work if you can connect via the web interface.
ssh pi@[same ip as in web interface]
Veröffentlicht : 06/10/2023 6:05 am
Walter Layher
(@walter-layher)
Short additional explanation: If you skipped the connectivity check you cannot be sure the Pi has received a valid DNS server address via DHCP. This can be set up during the connectivity check. If the connectivity check is successful, the plugins should be available also.
Veröffentlicht : 06/10/2023 6:16 am
Hello
(@hello)
Are you connecting through web interface ( putting ip into google) or are you going through monitor
Veröffentlicht : 06/10/2023 9:11 am
BillR94
(@billr94)
I am attaching the connectivity info. I can connect to port 1.1.1.1 but if I type in google.com or youtube,com, it does not connect.
Veröffentlicht : 06/10/2023 2:37 pm
BillR94
(@billr94)
Yes, through web interface. I put ip address into address bar from my laptop,
Veröffentlicht : 06/10/2023 2:39 pm
Seite 2 / 4
