Always beep when switch off the printer
Hi guys,
I assembled my printer several days ago. It works well except one problem:
Every time I switch the power off, I hear a beep from the printer. The next time I power it up and check the fail statics, the power failure counter will increment by one.
I tried power the printer off with printer fully cool down, it didn't work. The only way I can shut it down without a beep is to press the reset button then switch off the power immediately. I don't think this is a normal solution.
Did anyone experienced the same issue? I live in USA and the voltage here is 120V and I'm using the latest firmware for MK3S.
Thanks for any thoughts and help
RE: Always beep when switch off the printer
Sorry, apparently I posted in the wrong section.
bug in the firmware - to be fixed in the next release
