Aluminum Case mount for Raspberry Pi 4B (Octopi/Octoprint)
Laurent's Lab
(@laurents-lab)
After struggling with thermal issues on an (otherwise great) 3D-printed plastic mount for my 3B, I decided to switch to a better thermal solution for my new Pi4 (Octoprint).
I was looking at a passively-cooled option and researched the existing solutions including a mount for the whole Flirc case. Eventually, I decided to build a hybrid solution using the top of an aluminum case for cooling and a 3D-printed replacement bottom with the frame mount for the MK3/S.
I ordered a few different aluminum cases and ended up settling for the generic but solid and inexpensive Geekworm Heavy Duty case (Amazon). I recreated a matching bottom and added a mounted feature at the bottom to attach to the back on the MK3/S frame, above the electronics box. I printed the bottom in orange, mostly for the contrasting pictures, but it actually looks very nice, so I am planning to keep it that way.
PrusaPrinters
Thingiverse
Posted : 02/06/2020 11:03 pm
Agkirk
(@agkirk)
RE: Aluminum Case mount for Raspberry Pi 4B (Octopi/Octoprint)
Did you scan the Geeksworks case or did you manually create the CAD file for the .stl?  Nice job, I'm going to make one. Thanks
Posted : 03/06/2020 6:31 pm
Laurent's Lab
(@laurents-lab)
@1agkirk2
It's all measured with calipers and then designed from scratch in Fusion 360.
Here are some "mechanical samples" I printed to do fine alignment on edges and holes and test the printing of the fins and screw holes without support.
This post was modified 6 years ago by Laurent's Lab
Posted : 03/06/2020 6:57 pm
Agkirk
(@agkirk)
@laurent-m4
Impressive work product and thanks for taking the time to document your design effort.
Posted : 03/06/2020 7:03 pm
Gavin
(@gavin)
I assume you did not get the camera working on this ?
I do not see how you got the camera cable out of the case or is it possible ?
Posted : 12/05/2021 8:09 pm
Laurent's Lab
(@laurents-lab)
Posted by: @gavin
It is possible. If you look at the PrusaPrinters link in the original post, I recently added 3 photos at the end related to the lowered version of the mount (for lightbar compatibility) and you can see the camera cable coming out of the top. I have been using it that way since day 1.
It does require some amount of acrobatics with the ribbon cable inside the case, but not hard folding of any kind. At one point, you have do run vertically between the heatsink columns.
This post was modified 5 years ago by Laurent's Lab
Posted : 12/05/2021 8:57 pm
Great job.   I really like the detail on that.
Posted : 12/05/2021 11:58 pm
Gavin
(@gavin)
@laurents-lab
thank you for that info, awesome design, can you please post a picture of how you mounted the camera ?
thank you
Gavin
Posted : 13/05/2021 7:10 am
Laurent's Lab
(@laurents-lab)
Posted by: @gavin
@laurents-lab
thank you
Gavin
I use some version of this:
https://www.thingiverse.com/thing:2736439
The ribbon runs all the way from the top of the RPi case to the bottom, runs along the left side to the camera mount.
Posted : 13/05/2021 7:20 am
