        Slic3r PE suitable for other MM printers?
I wanted to use Slic3r PE to slice a model for an older Prusa i3, equipped with a Diamond hotend , to benefit from the smart purge tower functionality. However the gcode file comes with all the gcode to load and unload the MMU, which obviously doesn't work for my set-up.
Can this loading/unloading be disabled?
[Edit] Found out that removing the 'Single Extruder Multi Material' flag in Printer settings removes the load/unmoad code, but it also gets rid of the wipe tower, which was not the objective.
                            Posted : 13/02/2018 11:46 pm
                    Topic starter
 answered:
                        Re: Slic3r PE suitable for other MM printers?
The answer : https://github.com/prusa3d/Slic3r/issues/718 🙁
                            Posted : 14/02/2018 11:21 pm
I think so, just remove the tool-change g-code in the printer settings.
                            Posted : 19/02/2018 4:43 pm
