prusa firmware code snippet -> what the heck is going on there ?
JeffJordan
(@jeffjordan)
Member Moderator
hi guys,
actually I'm trying to modify the 3.0.12 firmware for my MK2 (and my clone) a little bit, so that I can use PJR's hyperfine bed levelling amendment (using the G80 command) and a modified bed level correction sub-menu (with eight values for "a" - "h") inside the calibration menu.
ok, I'm not very familiar with C / C++, so I often have to use the arduino sites or two books I bought about C and C++.
now I stumbled over a part of the firmware (inside Marlin_main.cpp) where a routine reads one of four values, stored inside the eeprom.
but I can't figure out how this works:
unsigned char *addr = (i < 2) ?
((i == 0) ? (unsigned char*)EEPROM_BED_CORRECTION_LEFT : (unsigned char*)EEPROM_BED_CORRECTION_RIGHT) :
((i == 2) ? (unsigned char*)EEPROM_BED_CORRECTION_FRONT : (unsigned char*)EEPROM_BED_CORRECTION_REAR);
correction = eeprom_read_int8(addr);
this part is inside a loop where i runs from 0 to 3.
correction is assigned as long int.
the EEPROM_BED_CORRECTION_... are EEPROM locations (defined inside Configuration.h), where the corresponding value is stored.
the value itself requires only one byte inside the EEPROM, so that we have four EEPROM_BED_CORRECTION locations, where a single byte is stored.
ok, *addr seems to be a pointer, but how is its value determined ?
and what the heck does "(unsigned char*)" attached to the EEPROM locations do ?
anyone here who could explain what's going on inside the first three lines posted in the code section ?
or somebody who can show me a simple way to read out a single parameter, stored at EEPROM_BED_CORRECTION_LEFT for example ?
Posted : 19/07/2017 1:53 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: prusa firmware code snippet -> what the heck is going on there ?
Yeah.
If i is equal to 0 carry out the next part else carry out the last part.
sorry, had to look again, there's another conditional:
Se we are defining an unsigned char pointer )addr) which becomes equal to the eeprom memory address according to the value of i.
If i < 2 it assigns either LEFT or RIGHT; if i = 0 it assigns LEFT else RIGHT
If i >=2 it assigns either FRONT or REAR; if i = 2 it assigns FRONT else REAR
so addr ends up containing the pointer to the L/R/F/B value within EEprom
Peter
Posted : 19/07/2017 4:33 pm
3DBastler
(@3dbastler)
To make it easier to understand I would write it like below (symbolic meant):
for (i = 0; i < 3; i++)
if (i < 2) then
// i = 0 or 1
if (i == 0) then
return_value = (unsigned char*)EEPROM_BED_CORRECTION_LEFT;
else
return_value = (unsigned char*)EEPROM_BED_CORRECTION_RIGHT;
else
// i = 2 or 3
if (i == 2) then
return_value = (unsigned char*)EEPROM_BED_CORRECTION_FRONT;
else
// i= 3
return_value = (unsigned char*)EEPROM_BED_CORRECTION_REAR;
return (return_value);
}// end for i = 0 to 3
Posted : 19/07/2017 4:39 pm
JeffJordan
(@jeffjordan)
Member Moderator
meanwhile I found a more structured way with using the switch & case commands.
and I figured out that (unsigned char*) allows you to convert the integer value of the EEPROM-address to a vector.
so my cases look like this one:switch (i) {
case 0:
{unsigned char *addr = (unsigned char*)EEPROM_BED_CORRECTION_PJR_A;
break;
now I finally managed to compile the 3.0.12 firmware with a "Bed level correct" submenu, where I can set manually all the eight correction values from -99 to +99 µm. and the lower case parsing of the G80 command should work as well. combinations are valid as well, so if I only send a "G80 b50" to the printer, it takes value a, and c to h out of the eeprom and uses the parsed 50 for value b.
in theory it should work, but until now, I haven't tested it with a print.
if somebody's willing to test as well, just sent me a pm. -> but without any warranty and at your own risk.
Posted : 19/07/2017 5:55 pm
