New Firmware 3.1.0-RC1
Page 2 / 2
chris.p8
(@chris-p8)
Re: New Firmware 3.1.0-RC1
Correction...
"When I do find a file and select it to print, the list then gets re-sorted, shows a limited number of files with the original selection highlighted and I have to select it again to get it to print??"
After the re-sort, when the original selection is highlighted if I wait for a couple of seconds it will start printing on it's own...
Chris
Posted : 20/10/2017 10:49 am
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Checkout https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/firmware-3-1-0-rc2-mk2-multi-material-mk2-s-mk1-t6454.html#p45064
Posted : 31/10/2017 1:53 pm
3d-gussner
(@3d-gussner)
3.1.0 firmware for Prusa i3 MK2/S/MMU with Hyperfine Bed Tuning and Filament Runout Sensor is ready
You can choose between tree hex files depending which languages you want/need to use.
https://github.com/3d-gussner/Prusa-Firmware/releases
Please let me know if there are any issues.
Waldemar aka 3d-gussner
Posted : 15/11/2017 2:25 pm
Knickohr
(@knickohr)
Member Moderator
My experience with Linear Advance :
- print 5 to 10° hotter (PLA) 😮
- set Infill/Perimeter overlap to 30%
- reduce Retraction to 0.5mm
- K=35 (for my slic3r settings)
Thomas
Posted : 27/12/2017 9:53 pm
james.h20
(@james-h20)
Thomas
Thanks a bunch for sharing ... yesterday I upgraded to latest firmware (3.1.0) and slic3r (2.1.0) (which defaults to using Linear Advance) and was immediately disappointed that every attempt to print was failing (material not sticking, stringing over gaps, etc.). Between these settings and slowing the fill speed from 100 down to 70 I'm getting successful prints again.
Posted : 29/12/2017 4:46 pm
Page 2 / 2
