Josef Question regarding newest slic3r included in drivers... unstable?
Whenever expecially when i cut a model in half .. or 30% of the time im using the program it freezes and i get a not responding message.
but when i use the stock program from the slic3r website i get no errors at all. its rock solid
is there a mk2 settings file i can load into the orignal slic3r program?
is there anykind of workaround so that i can use the program with mk2 settings in a stable enviroment?
thanks
Re: Josef Question regarding newest slic3r included in drivers... unstable?
anyone else having this problem?
fixes?
The Slic3r included in the drivers package contains a live preview of the cut. The cut function on its own may sometimes crash, but not so often as it seems. The bigger problem seems to be the live preview of the cut, which is too slow to be usable interactively. You can disable the live preview by unchecking the check box on the Cut object dialog.
The upcoming drivers will have the live preview disabled by default.
Vojtech
i assume slicing witht he stock slic3r program and importing the cut files into the prusa modified slic3r program will work fine?
thanks for the responce
