Importing to slic3r
roy.b
(@roy-b)
Importing to slic3r
Hi
Im just received my printer and it prints great. Im having a problem with importing my own models. Im using fusion 360 and saving the file as an stl. When opening it up with slic3r it reduces the object size tremendously. How do i import with out it be scaled down?
Posted : 17/05/2016 5:51 pm
Josef Průša
(@josef-prusa)
Member Admin
Re: Importing to slic3r
Check what units you are exporting to and make sure it is mm.
Founder and owner / Majitel a zakladatel
Posted : 17/05/2016 5:57 pm
roy.b
(@roy-b)
Thank you very much. That was the problem. What works for me is creating my model in fusion 360 in inches and once im done I change the units to mm and save it as stl. When opening it up in slic3r now its the correct dimension.
Posted : 19/05/2016 6:04 am
