Firmware Compiling Help - What is the exact process?
IsmaelPR1
(@ismaelpr1)
Hello,
I have downloaded Arduino, removed the Liquid Crystal library from it, I have also installed the Arduino Addons from the Repo as specified.
I have never used used Arduino before so I need to know the following:
• What are the libraries that need to be visible?
• What settings and options need to be selected and set before compiling?
• Please tell me everything that needs to be in place to successfully build and compile firmware for my Original Prusa I3.
I don't want to get this wrong.
When I ran compile I got the following message, can you tell me what is wrong, what am I missing?
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Build options changed, rebuilding all
Warning: platform.txt from core 'Marlin AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Bootloader file specified but missing: C:\Program Files (x86)\Arduino\hardware\marlin\avr\bootloaders\stk500boot_v2_mega2560.hex
Sketch uses 120,468 bytes (46%) of program storage space. Maximum is 258,048 bytes.
Global variables use 6,526 bytes of dynamic memory.
Posted : 07/05/2016 4:45 am
IsmaelPR1
(@ismaelpr1)
Re: Firmware Compiling Help - What is the exact process?
If anyone is interested, I figured it out and I wrote up some instructions on how to do this. You can download the PDF that I wrote up here: http://ifmarkllc.com/Misc/Orig_Prusa_i3_Plus_3D_Printer_Firmware_Build_Process.pdf
Posted : 11/05/2016 4:05 am
Josef Průša
(@josef-prusa)
Member Admin
Great tutorial!
Founder and owner / Majitel a zakladatel
Posted : 14/05/2016 2:15 pm
richard.l
(@richard-l)
Member Moderator
@josefprusa
When will the raw 3.0 firmware files be available for download and not just the hex files?
Posted : 20/05/2016 4:20 pm
fl0PPsy
(@fl0ppsy)
Yes I would need the source for v3.0 also. I need to adjust the e-steps slightly so that I get 1:1 scale prints.
Will the files be made available or will we only get precompiled hex files?
Posted : 22/05/2016 11:21 am
Cipis
(@cipis)
For now you can adjust e steps by adding M92 EXXX to starting script in slicer (or modify it if this line already exists).
Posted : 22/05/2016 9:56 pm
Josef Průša
(@josef-prusa)
Member Admin
3 series firmware code will be released this weekend when guys finish 3.0.1
Posted : 28/05/2016 12:09 am
