Cura settings
Alaingeenrits
(@alaingeenrits)
Cura settings
Hi all,
Sorry for a newbie question, I just assembled my new Prusa i3 ! I have Cura on my Mac, because I used it with Ultimaker printers in a Fablab (sorry...) and I would like to use it with the i3 now. Are the Reprap settings enough or anything special I need to change ? I found some threads here, but not clear what precisely is needed.
Veröffentlicht : 12/03/2016 1:34 am
Alaingeenrits
(@alaingeenrits)
Re: Cura settings
So I found the settings file in support, do I just load it as a profile ?
Veröffentlicht : 12/03/2016 1:48 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Cura settings
Hi Alain
Sorry but like many others here, I don't use Cura very often as the prints it produces are not the best quality.
When I have used it I have seen the "load profile" option and would presume that is what you need to do.
However, setting up Cura for this printer is very simple; just set the printable size and then set filament to 1.75mm and extrusion width to 0.4mm. I think that's about all I did to get going and then I tweaked as necessary.
Peter
Veröffentlicht : 12/03/2016 11:07 am
