Y endstop
Hi, firstimer here.
So my kit is finally done, selftest 100% fine and I started calibrating.
Z - all fine, then I have to calibrate 9 points.
Y endstop does not stop heatbed. Checked - clicking, when I test manually, wiring looks fine. What could be wrong?
Re: Y endstop
You can test the endstops using the LCD Menu's
try pushing the button with your finger to check it works at some level.
if it doesn't then the switch may be faulty, or incorrectly connected.
if it does work,
then there may be something stopping the y carriage operating the switch
