Y-Axis Movement Problem
I received y-direction endstop failure during 'self-test'. Found broken white wire under the factory-installed, black, insulative shrink sleeving on the end-stop end of the harness (black and white twisted pair). I removed the shrink sleeving, stripped wire and wound it around the end-stop terminal to re-test. This solved the problem. I will need to solder this termination for permanent fix.
Posted : 03/03/2017 8:23 pm
