Y Axis grinding
nathan.e
(@nathan-e)
Y Axis grinding
Hello again, I've been in the middle of calibrating my Prusa and have been having some trouble with the Y axis. Whenever I try and auto home it, it goes all the way to the back and all I get is a harsh grinding noise. I've installed the Y stepper correctly (as far as I know) but I can't seem to figure out the problem. Any help would be greatly appreciated.
Thanks so much,
Nate
I took a couple of videos showing the problem,
Posted : 06/02/2016 12:07 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Y Axis grinding
Hi Nathan
First thing to do is power off the printer. Then move the bed backwards by hand as far as it will go. Move the endstop forwards until it is tight up to the bearing. Ensure it switches - you should hear a click as it makes contact with the bearing.
Then move the bed forwards and then move the end stop forwards by 2 to 3 mm (1/8").
Power on and retest. Let us know the result please.
Peter
Posted : 06/02/2016 12:12 am
nathan.e
(@nathan-e)
Re: Y Axis grinding
Hi Peter,
It worked! Thanks so much for your help!
Nathan
Posted : 10/02/2016 8:57 pm
PJR
 PJR
(@pjr)
Re: Y Axis grinding
Hi Nathan
Great news. Thanks for the update.
Peter
Posted : 10/02/2016 9:06 pm
