X Carriage Can't Hit Endstop In Silent Mode
ReticulateLemur
(@reticulatelemur)
I've noticed that If I try to home my printer in silent mode when the Z axis is low enough to overlap the rambo cover box then I'm unable to hit the X axis endstop because the bundle of extruder cables will impact the rambo cover before the carriage can hit the endstop. This doesn't happen in high power mode, so I think it's just a function of the stepper not having enough power in silent mode to deflect the rambo cover enough.
Did I do something wrong with my build? I'm pretty sure I aligned the X endstop properly and pushed it all the way forward when screwing it on.
Posted : 22/04/2017 2:10 am
marathonmike
(@marathonmike)
Re: X Carriage Can't Hit Endstop In Silent Mode
I had the same issue this morning. I switched to silent mode this morning and it happened. Will try putting it back to power mode tonight.
Posted : 03/05/2017 6:51 pm
JeffJordan
(@jeffjordan)
Member Moderator
it is very likely that one of the zip-ties for the cable trunk, or at least the cable trunk itself interferes with the z-frame (or even the electronics housing) when located in the very right position. common problem...
Posted : 03/05/2017 7:38 pm
