        Where to put the PT-100 amplifier?
Has anyone switched from the standard thermistor to an E3D PT-100 thermometer with their amplifier board? If so, how did you mount the amplifier in the electronics box? Thanks.
                            Veröffentlicht : 04/10/2017 7:11 am
                    Re: Where to put the PT-100 amplifier?
Hi Chris, I'm looking for the same solution but didn't find any reliable info about wiring and connections.. Would you share your experience? Thanks!
                            Veröffentlicht : 16/04/2018 4:36 pm
I just printed a box and mounted it to the frame below the electronics enclosure, the wires from the thermistor were plenty long enough.
I used this post as a guide for wiring it to the Rambo.
                            Veröffentlicht : 16/04/2018 8:01 pm
