[SOLVED]Heatbed mounting holes overtightend - replacements ?
Hi
I accidentally overtightened two of he six mounting holes from the heat bed to the y carriage.
I can see that i can replace them when i remove the pei sheet. However i do not know what type of mounting pieces they are. I'm sure they can be bought somewhere but i don't know the name of them....
Could anyone help me out. At best with a link to amazon 🙂
Pic
Thanks a lot!
Re: Heatbed mounting holes overtightend - replacements ?
Manuel
Are you referring to the threaded hex stand-offs?
If so, you may find them in use in PCs, holding the motherboard away from the chassis.
Peter
Manuel
Peter
Thank you a lot! It turns out, that this was not the issue of my Heatbed tilt. See this thread: http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/heatbed-tilt-how-to-solve--t1951.html
Thanks
Re: [SOLVED]Heatbed mounting holes overtightend - replacements ?
So what was your issue? You posted your issue in the other thread but never replied to anyone.
Actually both. I was ayway a bit due to job change but im now back. Heatbed was tilted but is is solved now. But the spacers are still broken...
