Replace bed screws
Thomas Trutt
(@thomas-trutt)
Replace bed screws
Hi all,
so the other day after printing a spool of pla fell off the holder and hit the back portion on the bed. I broke down the bead, checked it (and straighten the frame -- from when i assembled it ) and put it back together. I checked the bed for noticeable damage and it seamed fine.. What i did notice is when i go to tighten the rear screws they just spin, i assume they are now stripped. I added a little thread lock (blue) on the rear screws which seems to have helped. My question is, is it possible to replace the threaded stands on the bed? if so how do you go about doing this and what replacements should i use?
Many thank..
Posted : 19/01/2017 2:06 am
ZARIBO
(@zaribo)
Re: Replace bed screws
I have the same issue with the left back screw, and I didn't drop anything, just replaced the bearings with extreme care and when assambling Ifound out that the back left (closest to the rambo board) slipping. If it is the same screw then there is a manufacturing fault.
Posted : 19/01/2017 5:05 pm
