Problem with extruder
Giuseppe Picazio
(@giuseppe-picazio)
I have a problem with the extruder of my printer. When I load the filament with the appropriated command the material exit from the extruder, but during the print I don't have any output.
Someone can help me?
Posted : 25/07/2016 3:08 pm
henrik.w
(@henrik-w)
Re: Problem with extruder
Hi!
See if the extruder plug is inserted in the socket on the Rambo mini in the right direction(the colors of the cables are in the same order as the other plugs e.g x motor).
/Henrik
Posted : 25/07/2016 9:45 pm
Giuseppe Picazio
(@giuseppe-picazio)
I have solved.
The problem was the connection of the cooling fan. I have inverted the cooling fan of the nozle with te cooling fan of the heatsink.
Thank you for the support.
Best regards
Posted : 26/07/2016 9:24 am
