Printing with 1 mm nozzle problem
Hi guys
I have been trying to print with my Prusa mk2 i3 using 1 mm nozzle and 0.6 mm layer height.
It seems that for each road, there are certain positions where there is less amount of material come out of the nozzle.
I have been trying every thing from changing the temp, speed and even the filament.
Does anyone knows where the problem is ?
Re: Printing with 1 mm nozzle problem
Please post your pictures on these forums. I will not look at third-party sites.
Are you trying to print at more than 15mm/s? That't about the maximum melt you will achieve with V6 hot end.
Peter
I am printing with 10 mm/s speed
I doubt the v6 can keep up with the volume of 1mm x 0.6mm...
And I am guessing you will have a huge stringy mess since even when not printing, that large an orifice will still seep filament.
I have had marginal success with 0.8mm nozzle with 0.4mm layer height. Looked a bit rough, and was stringy, but the machine could keep it primed.
Material? Temp? First layer height?
Does the extruder skip while printing?
Does the filament feed properly from the spool?
At least give us something to go on...
Peter
