MK3 wiggle test fails
andreas.j
(@andreas-j)
Hi
for several hours I am stuck at step 2 - the wiggle test. No matter what I do, as soon as it comes to tightening one aluminium extrusion, the whole frame starts to wiggle 1-2mm at one leg.
I disassembled everything several times and rotated parts, no success...
before I get the axe:
is there a trick not mentioned in the manual?
Opublikowany : 14/02/2018 12:16 pm
Neolker
(@neolker)
Re: MK3 wiggle test fails
Just don't overtight screws and follow the manual.
Opublikowany : 14/02/2018 12:24 pm
andreas.j
(@andreas-j)
If i had not done this at least a hundred times already :/
Opublikowany : 14/02/2018 12:28 pm
GertL
(@gertl)
Not sure if this is your issue, but anyway..
https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/warped-front-plate-t14294.html#p65901
Gert
Opublikowany : 14/02/2018 12:33 pm
Try putting a sliver of paper between the aluminium extrusion and the frame,
If you insert it at the top, the extrusion will point down, and if you insert it at the bottom, the extrusion will point up.
as the end of the extrusion is quite narrow, the effect of a sliver of paper will be more significant than you would expect.
Opublikowany : 14/02/2018 12:39 pm
andreas.j
(@andreas-j)
hi all,
the frontplates seem to be OK, as far as i can see.
the problem must be elsewhere, however i cannot find it.
Opublikowany : 14/02/2018 1:06 pm
stoofer
(@stoofer)
As a general tip, always tighten in opposites and a small amount at a time. So if you had 4 bolts when you look at them like this:
1 2
3 4
Then your tightening order would be something like 1, 4, 2, 3 (then again, then again, then again - a bit tighter every time). I would suggest it is possible that your first pass of tightening could be too tight, causing a skew.
This general rule does not apply if there is a more specific order, like the heated bed.
Opublikowany : 14/02/2018 2:43 pm
Peter L
(@peter-l)
If you read the comments in the online instructions, a lot of people have problems with this step. You are not alone.
I had a slight amount of wiggle in my assembly, maybe 0.5mm, but I went ahead and finished the assembly and it was OK in the end. The auto-calibration can correct for some defects.
1-2mm sounds like a lot and probably worth fixing. You can try the paper trick, and someone else suggested applying weight to the frame as you tighten the screws. You can also check all the ends of the extrusions for any burrs or other defects, as that would cause a problem.
Opublikowany : 14/02/2018 5:48 pm
HeySideburns
(@heysideburns)
I saw this nugget in the 2 months update blog post today that I hadn't seen before. Maybe it will help you.
"When finalizing the Y frame and tightening the front and back plates on the aluminum extrusions, do not over tighten the screws. It will cause the frame to wobble. You can also hold the extrusion with your other hand and gently twist the extrusion counterclockwise during the tightening."
Opublikowany : 14/02/2018 8:16 pm
andreas.j
(@andreas-j)
Morning all,
thanks for the tips!
The paper trick did it for me, wiggle as good as gone and the calibration reported i am "perpendicular".
So far so good, now lets go 😉
A
Opublikowany : 15/02/2018 8:01 am
Martin Wolfe
(@martin-wolfe)
I had a bit of problem with this step as well. It turned out not to be my printer that was failing this test but my work bench. I moved my printer to my desk after discovering that having my printer facing left right and front back gave different results. On my desk it passed this test straight away.
So I suggest you check the level of the work surface you are using to run this test on or try several surfaces and running it with the printer facing several different directions.
Martin Wolfe
Opublikowany : 15/02/2018 3:48 pm
