Maximum hotend temparature
Can you get your i3 MK2 nozzle to heat up to 295C?
Mine will not do it, 285C is the maximum I can sometimes achieve, but more often than not 285C also result in PREHEAT ERROR.
You do need to load suitable filament before you try it, polycarbonate for example, or you burn the plastic to a crisp inside of your hotend. 😳
Napsal : 22/12/2016 8:34 am
