M500 Command screwed up settings
So I'm trying to calibrate my extruder... I calculated that my steps/mm setting should be increased from the default 161.30 to 174.19 to get accurate filament metering.
I entered the commands:
M92 X100.0 Y100.0 Z400.0 E174.19
M500
Both returned "ok"
After rebooting my printer, I issued another M503 command, and got
Send: M503
Recv: echo:Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E0.0
Recv: echo:Maximum feedrates (mm/s):
Recv: echo: M203 X500.00 Y500.00 Z12.00 E0.00
Recv: echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X9000 Y9000 Z500 E10000
Recv: echo:Acceleration: S=acceleration, T=retract acceleration
Recv: echo: M204 S800.00 T1500.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.20 E0.00
Recv: echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P40.93 I4.88 D86.08
Recv: echo:Retract: S=Length (mm) F:Speed (mm/m) Z: ZLift (mm)
Recv: echo: M207 S3.00 F2700.00 Z0.00
Recv: echo:Recover: S=Extra length (mm) F:Speed (mm/m)
Recv: echo: M208 S0.00 F480.00
Recv: echo:Auto-Retract: S=0 to disable, 1 to interpret extrude-only moves as retracts or recoveries
Recv: echo: M209 S0
Recv: echo:Filament settings: Disabled
Recv: ok
Odd... zero steps/mm. Indeed when I tried to print, nothing extruded. I issued the M92 command again, and it is printing slow as molasses. A 0.100 benchy took more than 6 hours to print.
Unfortunately I didn't record the original values, so I'm not sure what other settings might have gotten screwed up that might be causing the super slow printing.
Re: M500 Command screwed up settings
After a little more Googling, it appears the follwing commands needed to be fixed. Any guess how that could happen? Did I fat finger something?
M92 X100.00 Y100.00 Z400.00 E174.19
M203 X500.00 Y500.00 Z12.00 E120.00
M204 S1500.00 T1500.00
M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.20 E2.50
After setting these 4 lines in the terminal, I issued an M500, M501, M503 and everything echoed back correctly. After another reboot of both the MK2 and the Octopi (for good measure), I again issued an M503 and got the following:
Send: M503
Recv: echo: M92 X100.00 Y100.00 Z400.00 E174.19
Recv: echo: M203 X500.00 Y500.00 Z12.00 E120.00
Recv: echo: M204 S1500.00 T1500.00
Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.20 E2.50
Recv: echo: M209 S0
Recv: ok
Seems to be miraculously fixed. I'll leave this here for others to search against, but I'm still baffled.
M500
Both returned "ok"
yeah, that's the problem.
the second one should return a "Settings Stored" message.
had this behaviour sometimes at the 3.0.10 (release) as well.
just reconnect (which will cause a reset of the printer) and run the commands again.
