loading filament = eject
Hello,
After a wonderful assembly of the kit, I made test and calibration,
and get OK for all
Ready to print, I hoped
But when I wanted to insert filament after preheating
I click on load filament, but the result is "Unload"
The motor doesn't push down filament inside extruder,
but push up the filament
because the motor turns in the bad side
What can I do, I forget anything ?
Thanks for help
Posted : 31/08/2017 5:27 pm
Re: loading filament = eject
Please check the way you attached the stepper to the RAMBO board.
Posted : 01/09/2017 4:05 am
