Limit switch
andrew.r17
(@andrew-r17)
Limit switch
Sometimes the limit switch (?) - the tiny black switch on the left side - seems too far away for the orange arm to press. The extruder moves over there and it makes quite a noise as it tries to keep moving beyond that.
The only way I seem to have managed to get it to press that switch is to raise the z acid above the height of the RAMBo box and then start a print.
Is there another way to solve this or is that ok?
Posted : 18/10/2017 12:14 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Limit switch
Your cable management behind the extruder is wrong.
Most likely the head of a cable tie is hitting the RAMBo case or the Z frame.
Peter
Posted : 18/10/2017 12:37 pm
andrew.r17
(@andrew-r17)
Re: Limit switch
Thanks mate - I will check that out when I get home 🙂
Posted : 18/10/2017 11:51 pm
