Layer adhesion problems
L33TFR34K
(@l33tfr34k)
I'm having some layer adhesion issues in layers other then the bottom. The prints have no problems adhering to the bed but the it seems that the top layers are fully bonding to each other. I'm able to pull apart the layers with very little force (or parts are snapping off).
Pictures attached show problems. Attached is also pic of a print I did on a makerbot several years the had much more flexibility then what I'm getting.
I tried raising the temp to 210C and that didn't have much of an effect. I can continue to raise the temp or possibly are the filament cooling fan speed.
Posted : 19/03/2017 6:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Layer adhesion problems
Print one of the pre-sliced models on the SD card - in this instance probably the castle or vase - you can stop the print after 50mm height and see how that is.
Peter
Posted : 20/03/2017 9:51 am
JeffJordan
(@jeffjordan)
Member Moderator
💡 i guess raising the temperature even more and lowering the printfan speed would be a good idea.
don't know which filament you use, but if it is pla try 220° and printfan @ 25%.
can you check if this happens with other filament too ?
some filaments are really not worth p&p....
Posted : 20/03/2017 12:21 pm
