Gaps in the first layer when printing ABS
johnny.y
(@johnny-y)
I'm having issues with gaps showing in the first layer. It almost isn't enough material extruded. I'm thinking the nozzle isn't close enough to the bed. I have adjusted live z to -0.16 already. I'm used to the old way of calibration with the single piece of paper method when I was using my flashforge printer. Is there a way to still do that with this printer?
I don't have gaps on any of the other layers. I tried adjusting the flow and nothing seems to have made any noticeable difference. I also played with the extrusion multiplier and that also did nothing.
http://imgur.com/a/OB4mT
See this picture. The one on the right was made by my old flash forge printer. The one in the red was made by the Prusa I3 MK2.
Posted : 25/08/2016 8:15 pm
David T.
(@david-t)
Re: Gaps in the first layer when printing ABS
Use live adjust Z and go lower with nozzle. I guess about 100um maybe even more.
Posted : 25/08/2016 10:13 pm
johnny.y
(@johnny-y)
Ok I did a combination of things. First I tried adjusting down more with the live z feature and it just wasn't going down enough. So what I did to fix it was to hit auto home and then used the live z down far enough and I put a sheet a paper to get it perfect. Live z was set to -.33 . First layer is perfect now.
It also fixed a sporadic warping issue with ABS with this as well. I think the printer is pretty much working really well.
Posted : 26/08/2016 3:54 pm
