Front calibration points not reachable
jamie
(@jamie)
First things first. this is an assembled by Prusa machine. It was working fine and then filament got stuck on the spool and a print stopped. it started printing horribly so I went through the XYZ calibration after noticing that my X and Y axis we not perpendicular. X axis rods and horizontal lines on bed were not parallel
When I ran the XYZ cal I got
XYZ Calibration failed, Front calibration points not reachable
In the handbook and at this link it says
XYZ calibration failed. Front calibration points not reachable. Even if the printer moves the table to the end Y end stop, the PINDA probe cannot reach the front row of the bed calibration points. Move both left / right Y threaded rods in the Z frame away from you.
I don't understand what it means to move the rods in the z frame away from me. I understand I'm adjusting the nuts on the Y rods that are at the vertical frame but I don't know what away from me means??
Posted : 21/05/2017 10:13 pm
Petri
(@petri)
Re: Front calibration points not reachable
Check this: http://help.prusa3d.com/mk2-movement-calibration/172660-p-i-n-d-a-probe-misaligned#_ga=2.268010253.2045689076.1498470621-117902804.1494935379
Posted : 27/06/2017 8:20 am
