					                		First layer issues - Prusa i3 kit (Archive)                                    </title>
                <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/</link>
                <lastBuildDate>Thu, 16 Apr 2026 01:46:53 +0000</lastBuildDate>
                        <title>Re: First layer issues</title>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41361</link>
                        <pubDate>Mon, 11 Sep 2017 10:11:52 +0000</pubDate>
                        <description><![CDATA[just provided a detailed description and a special set of gcodes on how to dial in the hyperfine bed levelling.
it took a little bit longer than expected, because my first attempt with the g...]]></description>
                        <content:encoded><![CDATA[just <a href="http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/hyperfine-bed-leveling--t4330-s110.html#p41311">provided a detailed description and a special set of gcodes on how to dial in the hyperfine bed levelling</a>.<br/>
it took a little bit longer than expected, because my first attempt with the gcodes didn't work as expected. but now it should be easy to understand and to use.<br/>
@walter: you can only go for max. +/-99 µm when using the altered firmware with the 8 correction values for the meshbed levelling through menu. <br/>
150 would be to much. but from the maths and the principle you are right.<br/>
if you need values between +/- 100 and 200, you've to use the G80 command and need to parse the values through the gcode to your printer, as proposed by PJR.]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/">Prusa i3 kit (Archive)</category>                        <dc:creator>JeffJordan</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41361</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41194</link>
                        <pubDate>Fri, 08 Sep 2017 19:26:01 +0000</pubDate>
                        <description><![CDATA[Thanks for the details
Just to make sure I understood the math behind this calibration:
Suppose I have set the &quot;live Z adjustment value&quot; at -350 in the bed center point.
I want now to adju...]]></description>
                        <content:encoded><![CDATA[<t>Thanks for the details<br/>
Just to make sure I understood the math behind this calibration:<br/>
Suppose I have set the "live Z adjustment value" at -350 in the bed center point.<br/>
I want now to adjust the "a" corner. My live Z adjustment for that corner is -500.<br/>
Am I right I need to enter -150 for "a" ? -500 -(-350)<br/>
When finished with the 8 points, I will set back -350 for my live Z adjustment value.<br/>
Hope that makes sense!<br/>
Thanks</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/">Prusa i3 kit (Archive)</category>                        <dc:creator>walter.v4</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41194</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41168</link>
                        <pubDate>Fri, 08 Sep 2017 08:29:36 +0000</pubDate>
                        <description><![CDATA[ps. I&#039;m going to make a proposal on how to dial in the values at the hyperfine meshbed levelling thread later on...
I&#039;d still be interested in your process, will you post it here or in ano...]]></description>
                        <content:encoded><![CDATA[<QUOTE author="shaun.k2" post_id="41138" time="1504814753" user_id="36298">
<QUOTE author="JeffJordan" post_id="40962" time="1504618009" user_id="7696">
ps. I'm going to make a proposal on how to dial in the values at the hyperfine meshbed levelling thread later on...
</QUOTE>
I'd still be interested in your process, will you post it here or in another thread?
</QUOTE>
I will post it at the hyperfine bed levelling thread, as soon as I've tested it here at my printers personally.<br/>
I've already prepared a set of tweaked gcodes, with a tiny test patch for every calibration point.<br/>
here in advance my idea on how to determine the required correction levels most efficient:<br/>
the idea is to dial in the center first with the live z adjustment. then note down the value  and proceed with printing single patches for every edge/corner without starting another meshbed levelling (G80), without disabling the steppers and without cooling down the hotend completely (bed remains heated as well).<br/>
then dialing in the correct z-height with the live z adjustment again for each corner/edge patch and writing down the determined value for the corresponding spot.<br/>
so you'll get 9 "live z adjustment values" in total. subtract the value of the center adjustment level from the remaining 8 and you'll get the 8 correction values to dial in for the 8 meshbed correction points.<br/>
and: don't forget the set the live z adjustment level back to the value you've determined for the center spot.<br/>
 :roll:]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41168</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41138</link>
                        <pubDate>Thu, 07 Sep 2017 22:05:53 +0000</pubDate>
                        <content:encoded><![CDATA[<QUOTE author="JeffJordan" post_id="40962" time="1504618009" user_id="7696">
</QUOTE>
I'd still be interested in your process, will you post it here or in another thread?]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/">Prusa i3 kit (Archive)</category>                        <dc:creator>shaun.k2</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-41138</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-40962</link>
                        <pubDate>Tue, 05 Sep 2017 15:26:49 +0000</pubDate>
                        <description><![CDATA[...
Should I be worried that the bumper on one of the Z axes is higher than the other? Is this an assembly fault and something I should fix before I go any further?
not essentially necessar...]]></description>
                        <content:encoded><![CDATA[<QUOTE author="shaun.k2" post_id="40931" time="1504576856" user_id="36298">
...<br/>
</QUOTE>
not essentially necessary, because the meshbed levelling should correct the slight skew of the axis, but it would make things easier to dial in the 8 values for the hyperfine bed correction.<br/>
ps. I'm going to make a proposal on how to dial in the values at the hyperfine meshbed levelling thread later on...]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-40962</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-40931</link>
                        <pubDate>Tue, 05 Sep 2017 04:00:56 +0000</pubDate>
                        <description><![CDATA[Okay so still no luck printing, seems like the moment the printer heats up, all the Live-Z values go out of whack. So I went back to Calibrate XYZ and started again. This time I measured the...]]></description>
                        <content:encoded><![CDATA[<QUOTE author="JeffJordan" post_id="40921" time="1504563374" user_id="7696">
<QUOTE author="shaun.k2" post_id="40899" time="1504549580" user_id="36298">
Okay so still no luck printing, seems like the moment the printer heats up, all the Live-Z values go out of whack. So I went back to Calibrate XYZ and started again. This time I measured the live-Z values at which the paper stops resisting for each of the 9 points around the bed....
</QUOTE>
but you still know that the <B>meshbed levelling only works during a print</B>, not when you move the extruder through the menu (either through the axis menu or the live z adjustment level) ?<br/>
so what you've "measured" with your values is only of limited usage... and only gives you the information, that your right "bumper" at the top of the z-axis is slightly lower than the left one.... so "calibrate z" delivers a slightly askew x-axis.
</QUOTE>
I had thought measuring these 9 values gives a good basis for a ballpark estimation of the hyperfine bed correction values. I should add that I flashed the hyperfine firmware, set a live Z of - 0.500mm to get the centre printing fine, and managed to get the rear left corner dialed in, but when it got to the middle left square (the one with - 770), the nozzle was printing into thin air even at +99 bed correction. So I might try to adjust the PINDA slightly to not get such a low value for that point on the bed. <br/>
Should I be worried that the bumper on one of the Z axes is higher than the other? Is this an assembly fault and something I should fix before I go any further?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/paged/2/#post-40931</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40921</link>
                        <pubDate>Tue, 05 Sep 2017 00:16:14 +0000</pubDate>
                        <content:encoded><![CDATA[<QUOTE author="shaun.k2" post_id="40899" time="1504549580" user_id="36298">
</QUOTE>
so what you've "measured" with your values is only of limited usage... and only gives you the information, that your right "bumper" at the top of the z-axis is slightly lower than the left one.... so "calibrate z" delivers a slightly askew x-axis.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40921</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40919</link>
                        <pubDate>Tue, 05 Sep 2017 00:02:02 +0000</pubDate>
                        <description><![CDATA[The picture of your first layer definitely looks like z-height issues. This threadhas a good description of getting your z-height set more accurately. It also has some pictures of first laye...]]></description>
                        <content:encoded><![CDATA[The picture of your first layer definitely looks like z-height issues. This thread <a href="http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html"><LINK_TEXT text="prusa-i3-kit-building-calibrating-first ... t2981.html">http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html</LINK_TEXT></a> has a good description of getting your z-height set more accurately. It also has some pictures of first layer issues that look a lot like your picture.]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/">Prusa i3 kit (Archive)</category>                        <dc:creator>Build Stuff With Bob</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40919</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40905</link>
                        <pubDate>Mon, 04 Sep 2017 22:16:41 +0000</pubDate>
                        <description><![CDATA[If you place a ruler across the bed, does the bed seem flat or bowed?  Check in both X and Y and at different places (edges, middle).
If the bed if flat-ish then you could try putting a was...]]></description>
                        <content:encoded><![CDATA[<t>If you place a ruler across the bed, does the bed seem flat or bowed?  Check in both X and Y and at different places (edges, middle).<br/>
If the bed if flat-ish then you could try putting a washer under the two right corners to bring those values up.<br/>
If it is this bowed, then trying the hyperfine bed level might be your best bet.<br/>
Since once corner is slow low, you may want to move the PINDA up a smidge.</t>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/">Prusa i3 kit (Archive)</category>                        <dc:creator>AJS</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40905</guid>
                        <link>https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40899</link>
                        <pubDate>Mon, 04 Sep 2017 20:26:20 +0000</pubDate>
                        <content:encoded><![CDATA[Okay so still no luck printing, seems like the moment the printer heats up, all the Live-Z values go out of whack. So I went back to Calibrate XYZ and started again. This time I measured the live-Z values at which the paper stops resisting for each of the 9 points around the bed.<br/>
<a href="https://i.imgur.com/mXrCVmV.jpg"><img src="https://i.imgur.com/mXrCVmV.jpg"></a><br/>
All measurements are in microns and the rear right spot is marked with an 'X" because the nozzle was already so close or touching the bed (even at Live-Z = 0.000mm)  that I couldn't fit the paper under it. This seems highly unusual..any idea why this happens? Calibration Z passes perfectly, and the PINDA probe centres itself in both circles more accurately than ever.<br/>
I feel like now is the time to try to hyperfine bed adjustment firmware..]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-prusa-i3-kit-archive/first-layer-issues-2-3-4-5/#post-40899</guid>
