Fanless PSU
Seite 1 / 2
andrew.f
(@andrew-f)
Fanless PSU
Has anyone replaced their fan based PSU with a fanless one, and if so, with what and where from?
Veröffentlicht : 27/01/2016 10:46 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Fanless PSU
Hi Andrew
My printer's PSU was fanless from when it was delivered. I don't think there is any problem replacing the PSU with whichever one you want, as long as it is specified at a minimum of 200 Watts @ 12 Volts.
Peter
Veröffentlicht : 27/01/2016 10:51 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
Your Prusa's PSU?
Veröffentlicht : 27/01/2016 10:53 pm
PJR
 PJR
(@pjr)
Re: Fanless PSU
Yes, my Prusa i3 original. No fans on the PSU. Just an extruder fan and a part fan.
Peter
Veröffentlicht : 27/01/2016 10:54 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
How odd. I bought my Prusa i3 original in 2016-01 and mine came with a fan.
Edit: apparently PSU with a fan is an improvement to prevent burn out, but I tell you I don't like it one bit.
Veröffentlicht : 27/01/2016 10:56 pm
PJR
 PJR
(@pjr)
Re: Fanless PSU
Generally PSUs with fans are the better option and the fan should only be working when needed.
Peter
Veröffentlicht : 27/01/2016 11:01 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
My PSU fan is always on. My Prusa has always resonated badly. I placed it on a sheet of foam, no joy. I printed and fitted the recommended anti-vibration mounts, no joy. I then combined the ant-vibration mounts and foam, no joy, then I placed a large thick sheet of glass under both and hey presto. No all I have to do is eliminate the as much fan noise as possible and the PSU is the prime candidate as it's a howler!
Veröffentlicht : 27/01/2016 11:21 pm
PJR
 PJR
(@pjr)
Re: Fanless PSU
Well, eBay would be a good source for a replacement (12V, 20A). Cost about £20.
You should check and adjust the voltage before installation.
I guess you could ask suppor (shop pages, live chat) if they could supply one if you wanted to stay "original". It it really is very noisy, you may even get them to ship a FOC replacement.
Peter
Veröffentlicht : 27/01/2016 11:27 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
For sure, I could buy off eBay or source elsewhere, but I thought I'd ask here first. I'm now chatting with support ...
Edit: ... and support here is outstanding, very much above and beyond expectations, so I have every confidence any kinks I highlight will be quickly ironed out.
Veröffentlicht : 27/01/2016 11:42 pm
erron.w
(@erron-w)
Re: Fanless PSU
Thats odd, I got my second one the 12th of this month, and mine doesn't have a fan. (I know my first from December didnt either) Though i actually wouldn't mind having one that has one (as my print room isnt always the coolest, specially in the summer.
Veröffentlicht : 28/01/2016 10:03 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
Sounds like a statement is needed from Prusa to explain the inconsistency.
Veröffentlicht : 28/01/2016 10:07 pm
PJR
 PJR
(@pjr)
Re: Fanless PSU
Yes, according to Jakub (support) they have had a shipment of PSUs with fans which are apparently proving quite reliable.
Peter
Veröffentlicht : 28/01/2016 10:11 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
Well, I appear to have ended up with a fan based PSU between the two fanless shipped to erron.w. I don't think enough time has elapsed to establish reliability, moreover, I'm more concerned about noise and less concerned with reliability if only 1-2 /100 fail. I'd prefer not to have a fan as it's as cold as a penguins arse here.
Veröffentlicht : 28/01/2016 10:18 pm
PJR
 PJR
(@pjr)
Re: Fanless PSU
Andrew
Just think of the fan as distributing surplus heat around your cold room...
Peter
Veröffentlicht : 28/01/2016 10:23 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
Rumbled! 😀
Veröffentlicht : 28/01/2016 10:27 pm
erron.w
(@erron-w)
Re: Fanless PSU
Seeing as how they use these machines to print all the parts for our machines, i'd bet they have been testing the PSU's with and without fans on their own printfarm 🙂
Veröffentlicht : 28/01/2016 11:05 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
That may be the case, but I'd hazard a guess that it's all been happening in a climate controlled farm room which doesn't reflect real world use. On one hand "Specially optimized firmware for quiet printing" and on the other a move from fanless to fanned, cancelling out the gain.
Veröffentlicht : 28/01/2016 11:23 pm
andrew.f
(@andrew-f)
Re: Fanless PSU
I've ordered up a sound level meter, which I hope will be here at the beginning of next week.
Veröffentlicht : 28/01/2016 11:35 pm
PJR
 PJR
(@pjr)
Re: Fanless PSU
Andrew
Sorry, but I really don't know where you are wanting to go with this.
If you had used the previous noisier version of firmware then you would now be very happy with the fan noise levels.
If the fan noise is really such a distraction, then instead of purchasing a sound level meter, you really should have invested in either some materials to box up the printer which would have provided other benefits in addition to reducing the sound levels, or a fanless PSU or even a replacement fan.
Personally I believe what we have from Josef and his team represents exceptional value for money, even more so when you take into account the superb support that is available.
When I got into 3D printing, I purchased a cheaper Chinese clone. Guess what. It was not cheaper at all. There was absolutely no support available whatsoever. It took me so many hours trying to get the printer working that it would have proved much cheaper to pay more in the first place. I also spent more than the cost of that printer in spare and replacement parts.
After what I have been through, to hear that someone is now buying a sound level meter just to prove how noisy his PSU fan is does sound rather ludicrous.
The fact that Josef is constantly striving to improve and perfect the printers he supplies should not be criticised in any way. Josef has very kindly published his hardware and software designs so that any one of us can take what he and his team have developed and make our own amendments in order that the printer performs as we want it to.
If you have any thoughts regarding improvements to this printer that you would like Josef to consider, then simply email him with those thoughts. He is always open to anything constructive.
Again, I do strongly believe that this product represents the best value in 3D printers available anywhere in the world and that we should be very grateful to Josef and his team for the efforts they put in to ensure that we are happy with what we have purchased.
Peter
Veröffentlicht : 29/01/2016 12:03 am
andrew.f
(@andrew-f)
Re: Fanless PSU
Peter,
Why would you need to know?
I opened this thread asking, “Has anyone replaced their fan based PSU with a fanless one, and if so, with what and where from?” and so far I’m the only one with a fan based CPU to post in this thread.
Odd that I should be the recipient of a fan based CPU when another ordering before and after me has received fan-less ones and no other with a fan based CPU has so far commented.
Advertising suggests a quiet printer, mine quite frankly is not and I care not what went before, I only care about what passes now and what could be done to improve it for that's what we should all be interested in.
If you add a fan based PSU to your Prusa then you may form the opinion the difference made by the firmware was subsequently drowned out.
Neither sound sound deadening nor box is an objective measure.
> is available.
Am I disputing this?
I’m not surprised. I decided to skip that step and order a pukka Prusa first.
Well, you’re thinking is wrong. You are jumping to conclusions.
It doesn’t help Josef or Prusa if people say bugger all where it matters.
I chatted with Josef last night and found him very receptive and I suggested an alternative to the anti-vibration mounts for his consideration.
My findings led me to this conclusion during due diligence research and I commended Josef last night for the outstanding level of support that goes above and beyond expectations and I also thanked him for what he’s done for 3D printing.
Knowing what I know now, it could be £50 cheaper, but I’m OK with that as Josef
needs to make a living and pay his very helpful and attentive staff.
> Peter
Andrew
Veröffentlicht : 29/01/2016 1:05 am
Seite 1 / 2
