Failed Calibration
lee.g2
(@lee-g2)
Failed Calibration
I have had several successful prints. Then for unknown reason octoprint wouldn't communicate with the printer so I reset to default but now It won't calibrate, measure the sensors to the bed and no luck made sure the distance is 100mm. Still failed, please help. Already have fw 3.0.11.
Posted : 10/06/2017 5:11 am
StephanK
(@stephank)
Re: Failed Calibration
Wild guess: Try lowering your PINDA sensor a tiny bit. This sometimes help..
Or we could try a more methodical approach: what exactly is happening when you try a full XYZ Calibration? What error are you getting?
PS: Watch your PINDA sensor, it has a faint red led that is light when idle and turns off when it detects the metal "target" at the calibration points (or when you hold a screwdriver under it)
Posted : 11/06/2017 2:03 am
